AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Yamaha Receiver + Marantz RC5200
post #1 of 3
Hi All,
I'm using a Yamaha A/V receiver which has a RS-232 port. Can I use the RC5200 to download information from my receiver?
BTW, just checked Yamaha's site. They've prodived a list of RS-232 code and IR codes. How do I use them?
post #2 of 3
post #3 of 3
the best place to start for codes is the file section at remotecentral. As for being able to do RS-232 codes the answer is no. But with the newer Yamaha that does not tend to be a problem
  Back to Forum: Remote Control Area
This thread is locked
