Originally Posted by Davenlr
Copy protection flags are only passed on digital connections. If you are using RCA connections, i.e. analog, there are no flags. Its got to be something in the Tivo software doing it. I know nothing about series 2. I jumped from Series 1 to TivoHD, and then Premier.
As far as I know, the "whole home" streaming only works between Premiers.
Nah, the streaming works between a whole range all the way back to pre-DT 2's.
What I think is going on is that the comcast box somehow puts the flag on the RCA outs to close the analog hole so people can't copy crap. That is what makes the most sense. And the TiVo software must have a way to detect it or something. Or it knows just by the lineup you choose it to show somehow triggers it automatically to apply that flag to close the analog hole. It just seems like a copy protection scheme to keep you from doing bad junk.
In any case, you didn't really tell me much about the sd tuner that I can use. Price and connection method are the key things. Does it only tune in the channels from the old analog basics (I.e. 2 - 69 or so)? Since it does SD only, I think that is what I really need to be using on that old TiVo to get the content my wife is wanting. So, if you don't mind, can you give me a little quick rundown on it or sow me a page to check out?
EDIT: do you mean that DTA box thingy? If so, I might have a neighbor that has a couple.
Oh well, this is good enough. And this new TiVo Premiere is working pretty well. Couple of snafu's at the beginning, but since then, smooth sailing. I wish it told you when things were blacked out instead of saying that the channel isn't available and to contact the provider. Kinda annoying.
