Originally posted by Azanon
[1.] ... I cant remember if you said Fox is transmitting digital full power yet.
[2.] ... Right now, both 7-1, and 11-1 are making my tv show a 4:3 image when i am in i1080 mode (my tv's native resolution). On those 2 channels, I have to put it on 480p to get it to fill my widescreen.
[1.] Fox (16-1) is the only digital broadcasting at full power from Shinall Mtn.
UPN (38-1) is the only digital broadcasing at full power from Redfield area (different tower than ABC (7-1).
If you want to try to get any missing channels, or if you later discover audio/video dropouts on 7-1 or 11-1, especially during weather/season changes, the CM 7777 preamp may solve your problems.
[2.] Your STB and TV formatting for 7-1 & 11-1 are working as they should for a 16:9 TV.
7-1 upconverts all SD/HD programming to 720p.
11-1 upconverts all SD/HD programming to 1080i.
Both of these channels are always in 16:9 format.
Any 4:3 programming on these channels is sent as a 16:9 image, with either black or gray bars on the sides of the 4:3 image to fill the 16:9 frame. The bar color is set by either the network or local station.
If your TV's brightness & contrast are set correctly (per AVIA
