AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Little Rock, AR - HDTV
Little Rock, AR - HDTV - Page 12
post #331 of 12336
shaneotool-are you able to pick up UPN? I have been able to get that without any problems. How long did it take from order to actual install?
post #332 of 12336
I ordered it on Thursday and it was installed yesterday. They could probably do it before the end of the month.
I have only been looking for digital stations, so I don't know if I can get UPN. What channel does it show up on your antenna? Is it digital? To be honest, I don't know of any shows on UPN that I watch.
post #333 of 12336
The only thing on UPN in HD is Enterprise. I only watch it if nothing else is on at that time. Digital 39, should remap to 38-1 for you.
post #334 of 12336
I guess I don't get it. I ran an auto scan last night and it went right past 39. Maybe my antenna is pointing in the wrong direction. I need to check into this.
post #335 of 12336
Jake 2.0 and usually the Friday Night movie are also in HD on UPN.
post #336 of 12336
If you have DirecTV or Dish Network please visit this site and complete the registration to send a letter to our state reps to stop this satellite only tax bill.
http://www.stopsatellitetax.com
post #337 of 12336
shaneotool,
KASN-DT broadcasts some HD programming on Wednesdays & Fridays.
Look at the map for your address at Antennaweb.org to make sure you're pointing the antenna in the right direction.
1. What OTA antenna are you using - is it the one you installed before, or did the satellite intaller put up a different OTA antenna for you?
3. Are you using a preamp?
4. Are you using a diplexor?
5. Is the dish they installed the oval "super dish"?
post #338 of 12336
When I look on antennaweb for stations that are available to me, KASN-DT isn't on the list. Maybe my house is in a bad spot to receive OTA from Pine Bluff. I still have my big Channel Master antenna and a pre-amp - it's pointed at Little Rock. I don't have a superdish installed and don't know what a diplexor is. I believe now they are only going to install a superdish if you need one to get your locals.
About the Dish 811 - it worked great last night. I don't know what happened but the digital audio output worked again - I got dolby digital on hbohd and hdnet.
Also the OTA tuner worked great - neither the picture or audio cut out once, and I watched CBS for about an hour. The performance last night was better than I had been getting with my motorola tuner. Right now, I am very happy with the 811. I hope it continues to work this well.
post #339 of 12336
shaneotool,
Did Antennaweb show any Pine Bluff/Redfield analog stations, like 2(pbs), 7(abc) or 38(upn)? If so, click on the "street map" and re-aim your antenna in the direction of those channels, to try and get KATV-DT or KASN-DT. You may be able to receive them, even though antennaweb doesn't list them.
post #340 of 12336
arxaw, It looks like to get channel abc and maybe upn I would have to have my antenna at 90 degrees. Right now it is pointed at 52 degrees to get cbs and fox. I would need a rotator to get all of them - not really sure if it would be worth all of the trouble. It's doubtful that I could receive them anyway as there is a hill by my house in that direction. I sure would like KATV though.
post #341 of 12336
I would at least try aiming the antenna that direction. Both of those stations have very tall towers. KASN-DT is broadcasting at full power 1,000 kW. I'm not sure about KATV-DT, though. Last I heard, they were only at ~20kW, but they may have increased their power. I used to receive KATV-DT at ~77% on the signal strength meter, but in the past month or so, they've been coming in at 100%. Both of those stations are about 25 miles from my house.
post #342 of 12336
Copy of e-mail sent to KARK
Dear Sir,
As a viewer of your station I have been sadly disappointed by what seems to be a lack of commitment to digital transmission of your stations signal. As one of the big 4 networks, it seems that KARK is doing the minimal amount that it can get by with to meet the government mandates for DTV. With the rapid growth of High Definition televisions and the new HD capable receivers that are coming into vogue in the cable and satellite markets it would seem to be prudent for a station of the stature of KARK to be moving aggressively to keep itself a player in the High Definition market before these viewers change their viewing habits. It would seem to be KARK's advantage to make this move before viewer ship is loss verses trying to reclaim viewers lost do to a lack of commitment to a changing viewer profile.
post #343 of 12336
dlott,
You should also contact KARK's owner, Nexstar Communications (you may have to snailmail a letter). Mention the fact that they are not serving the public interest because their 4kW digital station is too weak to be received in most areas of their city of license, and KARK-DT can't be received on cable because they have no HD.
At the bottom of the letter, put:
"CC: to Rick Chessen, FCC DTV Task Force Chairman".
You can send a copy via email to Mr. Chessen at:
rchessen@fcc.gov
post #344 of 12336
I have been having problems with KTHV's Live View Radar channel 11-2. The image would either be frozen or a black screen. I contacted KTHV and got this very prompt reply from Allison :
>We had troubles yesterday with our digital encoder at the studio.
>It should be ok today. We did, however, rob some bandwidth
>from the radar to give to the HD channel. So if the sweep on the
>radar is not smooth, that is why.
>We wanted to make sure the NFL playoffs and Superbowl
>coverage in HD had all the bandwidth we could give.
I wrote back and told her that although the radar subchannel is still not working on my TV, that was fine with me if it would improve PQ on the HD channel. I asked them to quit simulcasting all the time.
If you also wish that KTHV would completely do away with sub channels so HD would improve, please contact them and let them know.
technicalservices@todaysthv.com
post #345 of 12336
bump
post #346 of 12336
Thanks for writing us! We have just reduced the bandwidth on 11-2 to give
more to the HD channel. 11-2 is only taking about 5% of the total
available. I am going to see if I can take 11-2 temporarily off the air on
SuperBowl day so 11-1 can have the full bandwidth. I am not sure that
taking the radar off will completely eliminate all pixilation, some of what
you are seeing is incoming from CBS. Ah... modern technology. We
appreciate you watching us and appreciate the feedback.
post #347 of 12336
dlott,
Have you noticed any changes on 11-2 ?
post #348 of 12336
Haven't noticed a difference yet, but haven't had much of a chance to spend time watching lately. Here is a copy of what I sent Allison. We need to make sure that they know that the stations are being watched and we notice the efforts or lack of effort do do DTV right. Sorry for the personal commentary.
We would perfer that KTHV focus on the picture quality of their HD offerng
instead of simucasting the radar image that you are currently doing. With
the fine CBS offerings in HD it would be to KTHV's advantage to show that
they are the station with not only the best HD offerings but also the best
picture quality. Thanks for your time.
post #349 of 12336
Very similar to what I sent them
I hate to see bandwidth wasted on subchannels of something that's available elsewhere (like KTHV's web site), when that bandwidth could be used to improve KTHV's HD picture quality.
post #350 of 12336
I heard Fox is going to 720p by this fall. Does anyone know if KLRT will be ready to go for this when it happens?
To be more general, will there be any end-user HDTV advancements for us guys here in LR this year? The only thing i know of so far is supposedly D* will be adding a few HDTV channels this year, im not sure which.
Azanon
post #351 of 12336
KLRT-DT has been HD capable since day one. They can do 480i, 480p, 720p & 1080i. They are currently upconverting everything to 1080i, but may change to 720p when FOX-HD starts. ClearChannel owned KLRT-DT (fox) & KASN-DT (UPN) are the only stations in LR currently broadcasting at full power levels.
WB station KWBF-DT should be on the air by spring '04.
DirecTV is adding CBS-HD for people in O&O markets and in "white area" markets. This will be done by super bowl, but it will not affect viewers in the LR/PB DMA, since KTHV is not a CBS O&O station. DirecTV is also adding fox widescreen very soon, but it will not be available in LR either.
AFAIK, DirecTV's HD capacity will be max'd out when they add the above channels, until they launch another satellite sometime this quarter. If that sat launch is successful, it will also allow D* to add the LR local analog stations to their channel lineup.
post #352 of 12336
I'm glad you did this. I did notice that the games this weekend looked much better than a few months ago. Every single close-up back then was real blocky. Now it's not so bad. Thanks. If you want to get rid of it all together thats fine by me.
post #353 of 12336
shaneotool,
did you send that comment to the station?
post #354 of 12336
err... I will now. I was just skimming though this and thought dlott was from KTHV. opps!
post #355 of 12336
Good. Channel 11 actually enjoys hearing from DTV viewers.
email: technicalservices@todaysthv.com
post #356 of 12336
Might be time to e-mail, call, write, KARK to ask them to get serious about upgrading to HD now before August slips up on us and we are watching the Olympics in underpowered and marginal DTV.
post #357 of 12336
Good idea, dlott. Perry Chester is their general manager.
pchester@kark.com
Also contact Nexstar, KARK's owner.
post #358 of 12336
I contacted pchester@kark.com about getting HD on the air in time for the Olympics, but never got a reply. However a friend who wrote the station did get a short reply, and forwarded it to me:
">KARK will not be broadcasting in HDTV in time for the Olympics. "
nexstar sucks
post #359 of 12336
I emailed Perry last July to ask about the station's plans for hd. He did answer with the following
"Thanks for the inquiry. KARK,at this time ,has no plans to broadcast HDTV this year ,or even early next year.Our company just purchased KARK and there are higher priorities facing us at this time. Conversion to HDTV is important to us.However , it is not the most important item on our list. Thank you!
Perry Chester"
In the "real world" of business, the consumer would just have to find an alternative store/business that could supply the item/service requested. Not much choice with a monopolistic network affiliate!
I view Nbc on Directv via NYC and LA stations. Maybe Hdnet will be able to simulcast the olympics this summer like they have before.
post #360 of 12336
Originally posted by jstrossner
"... HDTV is important to us. However , it is not the most important item on our list...."
IMO, the most important thing on Nexstar's "list" is adding more infomercials during non-prime time slots. Nexstar's purchase of KARK has only taken our NBC affiliate from bad to worse, and they do not serve the public interest. Their sorry low power digital station doesn't even cover their city of license.
Where or how did you get a waiver? Did you uh, "move" your D* service address?
