JeffD: Nice setup, I bet you are glad you are getting the rack as I would be nervious with those components balanced on the TV.
I have my 50H82 in a corner and I built a shelf unit above it to hold my components and attached the speakers to it to keep everything away from my toddler. I will post a picture and update my list asap.
But, I really have a question about your Silver Sensor. I see it there in the pic, just aimed at a wall. And you get good results right. Is that an outside wall, or does it matter. You can't be any closer (as the crow flys) to the antennas than i am in West Ashley. I might use this as an add on, I actually have a window near by i was planning on mounting in? I am curious about your results.
Andy
Andy
. And for the antenna it does just fine pointing to the wall ,it is an outside wall and my house is brick . That is the direction towards Awendaw from my house and it's where I get the strongest signal which is good 90% - 95% strength . I can get Fox and UPN if I move the antenna around the little , like putting it in the window but then I lose reception of 5-1 . It's weird I can't get all 3 channels at one time but I can move the natenna to pick them up . A friend of mine bought one also and he gets a great sig from WCSC too .
