AVS › AVS Forum › Video Components › Video Processors › Convert 480p to 480i
post #1 of 8
Is there a cheap/easy way to convert component output 480p to 480i? This is mostly a convenience thing, so that I wouldn't have to run some components via S-Video and others via component, and constantly juggle inputs on my old-school NTSC set.
post #2 of 8
No.
The easiest thing to do is use S-video for everything, given that convenience of switching is your main concern. All 480p DVD players I know of will also output 480i component video with the flip of a switch.
(What else do you have that outputs 480p but not 480i component or S-video?)
Video hints:
http://members.aol.com/ajaynejr/video.htm
post #3 of 8
What about the other way, s-video to 480p component would be an improvement. Anything available under $300 for a single line source?
post #4 of 8
Yes, check out avtoolbox.com. They have a $100ish line doubler, and a decent scaler (AVT-3700) that does about every imaginable resolution between 480p and 1080i for a couple hundred more.
post #5 of 8
None of the avtoolbox items have component 480p output. It is all VGA or XGVA output.
Any other ideas for s-video to component 480p output?
post #6 of 8
You can get a transcoder of some kind and use the VGA out.
post #7 of 8
I'd look for a used iScan. It'll do a fine job and will meet your price.
-Dylan
post #8 of 8
Yep! iScan it is.
  Back to Forum: Video Processors
This thread is locked
