Jeff,
And they call ME "childish!"
I never watch any programs with black bars on the sides. With Sony's "wide mode", there is no reason to. If there was no wide mode, this TV wouldn't be in my house. I would have waited, unless my other TV had broken.
No I don't!
Yes you do. You also get the bars on ANYTHING broadcast in widescreen.
In case you haven't been told, in a few years, everything will be in wide screen! Really!!
Here's a new one for you:
I would bet you that if you could pick 100 people (that couldn't care less about aspect ratios or anything else being discussed on this board), that at least 90 of them would like the looks of the 34 over the 32,36,40.
Ah, so you say what does that have to do with anything?
I think quite a bit. Ever buy a car? Before going for a drive or checking out it's specs, before kicking the tires, don't you check out how it looks? Of course, that has nothing to do with how the car will perform, but it's still important. Same with the TV. I admit this doesn't prove anything, but I think that whether you want to admit it or not, it's still important.
Okay, let's see what else you said.
That's ridiculous. This reminds me of a quote from Jim Ignatowski (know him?) When told that there were five hundred thousand people at Woodstock, he said that it was lucky that he went or there would have only been four hundred ninety nine thousand nine hundred ninety nine!
Okay, anything else? Ya know, I am A.D.D. and I like to take on one issue at a time.
I disagree. What else can I say?
Ah, looks like you got me on that one.
Why is it you 4:3 guys (Delvo excluded) are into name calling? Is that the only way to make your point?
All the rest is just rehashing everything again.
Was your entertainment center really five grand?
Please make all future notes smaller.
This is too much for me. . .
Eneg
| Since you dispise the black bars so much then why even settle for 1 aspect ratio? Just don't watch anything because black bars are a part of life in 4x3 or 16x9, If you can't accept it like the rest of us then you need to find a new hobby. |
| I see, you would rather have black bars on the sides instead of the top and bottom. That makes sense and validates your concern for the black bars. |
| With a 16x9 set you get bars on 4x3 and 2.35:1 material. |
| With a 4x3 set you get bars on 16x9 and 2.35:1 material. |
| So what stations converted to 16x9 HD this month? Which ones did last month? Which ones in Dec? Which ones in Nov? If you have a list, please share with us... |
| RPTV's will be arround in 5 years, I guarentee it. If plasma or LCD is the better buy in 5 years so be it. That wasn't the point of my statement. The point is I will have a 16x9 set when I need it and right now I don't need it. So don't tell me to plan for the future as I already have. Much more efficiently I might add. |
| Also, no HDTV cable in my area. A STB will run me over $600 minimum! No renting of STB's in my area at all and not for several years at least so your comment means nothing there. |
| And your B&W RS comment was just plain dumb, now you're being silly. |
Eneg
