AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Central New Jersey - OTA
Central New Jersey - OTA - Page 80
post #2371 of 2383
Originally Posted by Antenna_Matt View Post
Hello all,
I'd like to get some of the VHF-Hi channels here in Princeton NJ, especially ABC 6 and WHYY PBS 12. Here's a link to my TV Fool:
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d81a3e3e689b37a"]http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d81a3e3e689b37a
Can anyone recommend a good antenna and preamp, if necessary? I'd like to stick it in my attic, as there's really no way you're gonna get me on top of my roof (plus the homeowners' association frowns upon it). I know I'll lose some signal strength and that the homeowner's association can't stop me.
I am also very handy, so if anyone has a link to something I can build that'd be fine as well!
Thank you!!
Matt
Matt,
I installed two Channel Master CM3016 VHF/UHF suburban antennas in the attic of my two story frame colonial. One is aimed at New York City, about 40 miles to my northeast; the other at Philly 50 miles to my southwest). (My exact location- Southeastern Hillsborough NJ, N40° 28.3688', W074° 35.7299', about 10 miles north of Princeton). Antenna 1 hangs from an attic rafter and is pointed at NYC about four feet behind and about nine feet to the left of antenna 2, which is pointed at Philly.
The two antennas are combined (using a splitter in reverse), then immediately split using a second splitter.
A coax runs from the splitter output 1 to the basement, to a cheap Radio Shack 12db VHF-UHF distribution amplifier. It is then splitt four ways- to two digital converter boxes/TV's, one Hauppauge HVR950 ATSC stick/Dell PC, and one stereo FM receiver.
A coax runs from the spltter output 2 to a second spitter, then to two tv's in bedrooms beneath on the second floor (no amp in this branch)
Equipment:
Devices on Antenna: 1 (Zenith DTT901 digital converter, 1 Magnavox TB100MW9 digital converter, and 1 HVR950)
Device on Antenna 2: Zenith DTT901 digital converter
Reception is strong on all stations from both NYC and Philly (including VHF 7, 11, 13 and 6, 12). I did have to play around with the antenna locations to get good reception from both cities; many trips up to the attic until I found the 'sweet spot', but in the end was able to get excellent digital reception from both cities without the need of an antenna rotator.
Frank
WA2ISK
post #2372 of 2383
I'm surprised that you're using a CM-3016. The web-site says the range is 45 miles. Am I wrong in assuming that I would need a 60-mile range antenna to compensate for the loss I experience from the attic installation?
Matt
post #2373 of 2383
Matt
Matt,
You are correct. The salesman at Solid Signal also said the CM-3016 said mounting in attic would probably be a problem. But due to attic constraints, I took a gamble and they are working in my attic (but as noted I did a lot of experimenting and moving them around to find hot spots where they worked for all channels. Particularly difficult was 13 from NYC and 12 from Philly). Since they are hard to return, if you have a lot of room in your attic, go for the next size up (CM3018, or CM2020 if you don't care about Philly channel 6).
Frank
Frank
post #2374 of 2383
NJN, New Jersey Public television quietlywent off the air as of Thursday, June 30th. It has been taken over (at least Channel 52.x WNJT here in central NJ), by NJ Public Media and re-named NJTV-52. The details are still a bit murky, but there is apparently some form of 5-year management contract between the NJ Public Broadcasting Authority (NJPBA) and both WNET in the NYC area & WHYY in the south NJ/Philly area to continue operations as a non-profit entity with NJ focussed public interest programing and broader appeal standard PBS productions. Interestingly, NJPBA has retained the four FCC broadcast licenses, (RF-22-WNJS-23-Camden, RF-43-WNJT-52-Trenton, RF-51-WNJN-50-Montclair,RF-8-WNJB-58-New Brunswick), perhaps anticipating cashing in on the FCCs' proposed spectrum auction?
post #2375 of 2383
seriously doubt that, new jersey has the right to recall their licenses if they feel that wnet managing their stations now, has not kept their end of their deal, as far fcc auctioning off the tv spectrum is plain bs.
post #2376 of 2383
The state still owns the licenses. It's just that the stations are no longer being run by the state.
post #2377 of 2383
Actually, WHYY bought NJN radio stations in the South Jersey area, they are not at all involved in the NJTV television management. That is totally controled by a WNET- Thirteen subsidiary.
post #2378 of 2383
The State of New Jersey retained the NJN TV broadcast licenses (four transmitter sites), and the State continues to maintain and operate the transmitters at those sites. The contract with Public Media NJ concerns the provision of content to be transmitted.
And yes, the reason why the State retained the licenses - why the Legislature mandated that the TV licenses not be sold - is the anticipation that they may have value in some future spectrum aucthion.
This was not an issue for the radio operations, and as a result, all the former NJN radio licenses are in the process of being sold - those in northern New Jersey to New York Public Radio, and those in southern New Jersey to WHYY. In both cases, the stations are currently being operated by the assumed buyers, under operating agreements, pending FCC approval of the license transfers. In the south, WHYY is using these stations as extensions of it's primary broadcast area, feeding them the same programming as is on WHYY-FM. In the north, NYPR has chosen to maintain operations, as New Jersey Public Radio, with more or less the same programming that NJN used to carry...even to the extent of picking up and broadcasting the audio from the New Jersey Today, Summer Edition "newscasts" that are on NJTV. Presumably, the content on NJPR will change once the sale to NYPR is finalized.
post #2379 of 2383
Any new updates on what OTA you can get from Jersey (notably the Jersey shore - Asbury Park area)
post #2380 of 2383
OTA in Summit NJ, (~25 mi. west of ESB transmitter), has been losing channels 2 & 4 in the evening for the past couple of weeks. Reception is strong during the day but drops out around 8PM. Anyone else experiencing this?
post #2381 of 2383
There's been very strong atmospheric propagation the past few days. I live in Alexandria, VA and decoded several stations from Boston a day or two ago.
A friend in Connecticut has seen stations as far away as North Carolina within the last 24 hours.
- Trip
post #2382 of 2383
Hey guys.
I'm in Hillsborough, NJ and comcast just cut our free OTA channels that we were picking up without additional hardware.
I'm not very experienced in installing outdoor antennas, etc. What are my options?
Here is my tvfool analysis:
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d46ae683463f9a5
Is indoor an option? It looks like the New York channels are about 39 miles away.
I only really watch the major locals: CBS, NBC, FOX, ABC, PIX.
I'll have to figure out how the wiring throughout my house goes in order to properly feed an outdoor signal.
Plus mounting and running wire. Seems like a lot of work that's probably out of my league.
post #2383 of 2383
I live in the south eastern section of Hillsborough. I have two suburban vhf-uhf antennas in my attic, one directed at NYC, the other at Philly. I combine them using a splitter (in reverse), through an amplifier ( a good one) then split to tv's on second, first floor and basement. Get all stations in NYC, and all in Phily except 29. Comcast doesn't carry most Philly channels, so big plus. During Sandy power outage, I was only one in neighborhood that could watch tv (when my generator was running).
Let me know if you want additional info on how my house is wired for tv.
Frank
