Here's a response from the DVD forum:
Originally posted by ssj2
The Momitsu is the only player currently available that will output an analog RGB 720P and/or 1080i signal that can be used with a CRT projector. Does anyone have this combination, and if so, what kind of results are you getting? Thanks.
If it's rear-projection CRT that you're inquiring about, I do(a year
2001 RCA Scenium 65-inch hi-def RPTV) and the results are
nothing short of EXTRAORDINARY. And that's with component to
component connection with the slight intrinsic high-frequency
rolloff resulting from the digital to analog to digital permutation.
The image is fully equal to any D-VHS, or HDTV movie broadcast
by CBS or ABC, I've ever seen when viewing any high-quality
current-generation DVD. Couple evenings ago I watched 'Cradle
2 The Grave', which is not even a SuperBit, and the result just
about knocked me off the chair. The resolution, clarity, color
saturation and all the rest of it has an almost translucent, 3-D
quality to it. It's image is mesmerizing at 1080i.
Word of caution: the Sigma Designs EM8500 decoder/board
which drives this machine and the Bravo D-1 does not work
with all displays, so you may want to check with Manowa/Momitsu
to see if they have an installed database large enough yet
to be able to tell you if your particular display poses any
problems.
Good luck!
Milt R. Smith
mrsmith2002@yahoo.com
