Erik,
I know I described soldering the HD15 connector as tedious but it was not that bad and when complete you do get a sense of satisfaction having done it all yourself. It is also best to keep the number of connectors down to a minimum.
I think around $20 at radioshack will get you everything you need to try and solder some cables yourself. Just remember that you heat up the wire/pin joint and let the solder melt on the wire-pin joint and NOT on the soldering gun tip that is heating everything up. It does take a few moments for the joint to heat up and once it does, the solder just flows and with that you are done.
The Dsub 15 pin male connectors at Radio Shack have "hollow pins" to solder to, so that the CAT5 wires fit perfectly inside this mini tube, which makes things very easy.
The hardest part for me was getting the wires stripped, and getting all the wires to the correct length. I had stranded cable which I had to twist once I had the insulation stripped. Then I would clip the exposed wire to the correct length.
I really wish a good write up existed like the one on how to make your own Canare RG6 cables for audio/video/antenna. I will try and take some pictures with the next one I do, get approval from Mr. Wiggles to make sure my technique is right and then post it. But that won't be for another few weeks. Hopefully the AMP connector will be available by then but even after that I know some folks may still want to solder their own for whatever reason.
All the best,
Ricardo
All the best,
Ricardo
I expected multiple ghosting all over the place but there's only one ghost 5 pixels to the right at 1024x768 60Hz. At 800x600 60Hz it's very faint, although that could also be a result of the scaling in the projector.
