More likely, you may have some loose connections, or old splitters not rated for full 1 GHz digital cable operation - from back in the days when there were no cable channels > 100. Ch. 111 (717 MHz) is near the upper end of Comcasts QAM frequencies.
post #14971 of 15821
7/7/10 at 3:42pm
- jimre
- Trader Feedback: 0
- offline
- 2,012 Posts. Joined 11/2001
- Select All Posts By This User
KCPQ-HD and KSTW-HD (Comcast 113 and 111) are both transmitted on physical QAM ch. 111 -- so it's likely something to do with your ability to receive that frequency. Could be outside interference or ingress, but that's the old UHF ch 55 range - which is no longer used. I think it was recently aunctioned off along with the rest of the 700Mhz spectrum to Verizon or somebody like that.
