Originally posted by chris5977
2. There is no CBS HD and it has a lot of good programming. Why can't Comcast just buy a freakin' OTA STB and rebroadcast channel 7!?
Um... because it's not theirs, and they'd be thrown in jail for stealing it? Comcast is happily showing local CBS-HD affiliates in many markets - so I place the blame for this one squarely on KIRO and their owner Cox Communications for dragging out the negotiations witn Comcast.
4. The Comcast analog channels (100 and under) look awful. They look like poor reception OTA and have some interference. I always had perfect PQ, except for the occasional storm, with the non HD stuff on Directv.
Well, that's digital for you. It's either perfect, or non-existent. Maybe you need to check your analog signal levels. My analog PQ on Comcast isn't as good as digital - but it's not bad. I had to add a couple signal amps to my distribution system to improve my analog PQ.
5. My daughter's favorite channel, PBS Kids (110) inexplicibly turns to a black screen for hours at a time when the TV Guide says it should be showing content.
Well, ch. 110 isn't really PBSKids channel. It's a part-time channel aired by the local PBS affiliate - "KCTS for Kids". They only broadcast 7a - 5p. After 5p they use the bandwidth to air their HD channel (108 on Comcast). I don't know why their guide data is so far off, but the Comcast guide is mostly useless anyway. The actual schedule for this channel can be found
here.
7. I ordered three HD cable boxes for my three HD TVs. The guy showed up with one HD STB and the rest SD. I called and complained and they said that because of high demand they only allow one per household.
That's just BS. I ordered two HD boxes and they happily installed both of them, no questions asked.
