Originally Posted by
johnnyicemaker
Is there a smaller HDMI receiver box available in the Seattle area other than the Motorola DCH3200. I have a flat screen on the wall and a small shelf below to hold the box, but the DCH3200 is SO big! Need something smaller to look more in place in a bedroom. No need for a DVR if that makes a difference.
The DCX3200M and RNG110 might work for you. There is a relatively easy way to get the DCX3200 if you have a need for Multiroom. You're guarenteed to get one as part of the Multiroom setup. It requires a truck roll so you'll need to call Comcast.
The RNG110 is another solution an is slight smaller than the the DCX3200 but not by much. I've had lots of problems with this box but I was an early adopter. I was told that early releases of the boxes were problematic and that later versions work better so you're luck may be better than mine. That said, it's luck of the draw as to what you'll get at the Comcast store.
These boxes are a LOT smaller than the DCH series. As an example, I have one of mine mounted under my kitchen cabinets and am using velcro to hold it in place. Works great.
