Originally Posted by
sixt5cuda
I have been having the same problem for at least a week. Right now, KingDT shows up completely blank when I tune to it.
(I am using 2 HDHomerun tuners and BeyondTV software)
Same here, it is a systemic problem with what channels Comcast uses to send KING5 over...they are among the lowest frequency, and thus if you have even somewhat low signal or a few splits, you will have trouble. All the TVs in my house, even with a powered amp that Comcast put in, have trouble getting it from time to time, and my HD Homerun almost ALWAYS has trouble with it
You can see for yourself if you are having troubles due to strength if you try the tap where it comes into your house instead of after it's in your house with a bunch of splitters...sad, there's not a lot that can be done about it (especially if you split 8-ways like I do, for my HD-Homeruns and so forth
This could EASILY be solved by Comcast if they would broadcast it further up the foodchain, but of course, they don't
