Just found this thread and realized how much I have been missing out!
I have built an HD HTPC system using MyHDII with DVI and had some success pulling in some OTA channels with an RS VU-75XR 18 element yagi mouted in the attic with an RS Cable TV high gain amplifier. Of the channels I care about receiving, only channel 48 (NBC/King) is unreliable with significant dropouts even when pointed for optimum signal.
I have exprimented with the Zenith SS with no success and was also thinking of the trying the Xium. After reading this entire thread, I am inclined to try the CM4228. Before I do....
Larry: would you be so kind as to check the LOS for intersection of SE 24th Way and 194th Ave SE in Sammamish (some maps have this as Issaquah)? Given that, can you tell me if the CM4228 or Xium would improve my situation over the RS setup?
Thank you very much - and how do I drop in my $0.25?
Kenny
