Originally Posted by Hi Def Fan
Can we get someone that knows what's going on at KOMO in here? They must have changed the way they did something because I was getting 4.1 and 4.2 fine before the rollover. Now I get nothing after rescanning twice and fiddling with my antenna cable a lot. I also don't get why DTV 4-0 shows on the channel indicator when hitting the 4 button now rather than DTV 4-1.
Short of buying an indoor antenna at Radio Shack to see if that works, I don't know what to do. I tried a Terk directional fishbone type before and had to return it because it didn't work well. I may try a UHF/rabbit ear type this time though. The guy at the lower Queen Anne RS store showed me how well that type works in their store for KOMO, and I live only about 8 blks SE of their store.
Can someone post a link to FCC info where I can find what KOMO has done if anything to change the way they broadcast? Thanks in advance for any help, this forum rocks!
And a special shout out to Dan Kurts, whom I know is doing heroic things wherever his superpowers take him.
Hey Hi Def !
No superpowers, just too much time on the roof!
Did you get the KOMO prob sorted?
Dan
I'm planning on installing this on my roof.
