Originally Posted by DanKurts
Sherry
I'm trying to see which house is yours from the Google Earth shot.
North up 48th, on the west side of the road, the third house from 220th appears to have a brown roof, with an outbuilding that has a red roof. The 4th house up is about 100ft further north, light colored roof and sits at a 45 degree angle to the road. On the east side of 48th, about 150ft north of 220th, is an L shaped house with a big driveway and parking area. Where are you in relation to these houses?
KIRO translator from MT Vernon should be line of sight, almost due north. It doesn't have much power, but it's only 20 miles. Lowering your antenna should still receive it with all that equipment you're using. The nearest hill is across the valley, 3 miles away, not a big problem.
Also, when you had everything working okay, did you ever swing the antenna around to the south east and try for Tiger MT, by Issaquah, for ch51 KIRO? It's very high and should be line of sight as well. A lot farther, but could work, too.
As for KVOS and Vancouver, I would like to see which house is yours to get a better idea of what you're fighting.
I would bet we could get you back down to a reasonable height of 10ft to 20ft at the original location.
As for a good tuner, I found the ChannelMaster to be very sensitive and selective. I carry one in my van for testing. Works at very low levels of signal, below the minimum of what my meter reads, at -25db. Most TV's won't work below -15db. They carry two flavors at Fry's. One regular HD model
http://www.frys.com/product/6598413
The other comes with a DVR built in and two tuners
http://www.frys.com/product/6147839
Both have HDMI and optical outputs so you can run them through a good receiver and surround speakers.
The only good field strength meters I've seen start at $1500. Mine was over that, and my Sencore was almost $3000. They're invaluable because they show you more than just signal level. They give you an oscilloscope type view and the resulting waveshape is very important. Really helps you see what is going on.
Let me know which house is yours so I can check the tree situation a bit more. I love a good challenge!
Dan
Sherry
Dan
Hi Dan,
That’s me with the brown roof, and red garage roof (I guess I’m not very good at estimating distances by feet!). There is an enclosed porch on the south end of the house which also has a red metal roof. The antenna is currently sitting on top of this roof.
When I first had the antenna installed, I moved that antenna around every which way trying to get something from Seattle - including all those from Tiger Mountain - although was mostly hoping for K29ED coming from Everett in that direction (a translator for KZJO, which in turn rebroadcasts KCPQ - was hoping to get my FOX that way). It’s only 17 miles away, but there must be a hill in the way that I can’t see). I got nothing.
I want to clarify that I can hook up a digital converter box (ie, the ChannelMaster you mention) to a digital TV?
Thanks again for your help!
If I can manage to get the sucker down, I might actually be able to get it back up to 20ft by myself!
Sherry
