Originally Posted by trode
Turns out my problem ended up being a bad network switch and a firewire tuner that wasn't able to tune well.
I started from scratch and tested all available tuners including the LCD tv. It was able to get all channels without issue. The tip I would share with network attached tuners is to try directly connecting them to a computer via ethernet port and test them that way. That is how I determined that it had to be a network issue when they worked properly that way. I swapped out a 8 port netgear switch with an older 5 port one and now everything works. The switch was failing is such a way that normal tests like ping did not show any problems..
What really confused me was the old firewire tuner was failing in a similar way on the same channels. I have retired the EyeTV 500 and now am using 2 HDHomeRun's to get 4 tuners via the network.
Thanks for the help Jim/Dan and the rest of the posters!
trode
You're welcome. Thanks for the challenge. I had no idea your Mac tuner devices were streaming. Learned another one!
By the way, the ping is very low on the OSI stack. My old laptop I use for programming on site fails a ping, but works fine otherwise. Not worth repairing.
Your basic instinct and troubleshooting methods were right on. If you have another failure, try the Linksys/Cisco hardware. I don't like callbacks, and have been bitten with a variety of hardware and software issues with D-link, Netgear, ASUS and others. There probably are others out there with great reliabilty, but my luck has held well using Linksys/Cisco, and the 24/7 free support is decent, and their tier2 support is great.
After all this, you have the cleanest antenna install around !
Dan
