Originally Posted by mickey79
Hi Dan -- Thanks for the explanation.
I've been doing some research on my own and I've started to realize, just as you stated, things like trees & even building materials will prevent catching stations. At first I was just looking at technical values stated by TVFool.Com ... but I do understand what you're saying about top of me from Tiger Mt. and the others being NW of me.
Nearest cross st from me is SE 276th & 216th Ave SE. Nearest major one is SE 272nd & 216th Ave SE. They're both like 2 ~ 3 minutes from my house.
This is the cross street: http://maps.google.com/maps?q=SE+276th+street+%26+216th+Ave+SE,+Maple+Valley,+WA&hl=en&sll=47.355782,-122.055981&sspn=0.005444,0.009474&t=h&hnear=216th+Ave+SE+%26+SE+276th+St,+Maple+Valley,+King,+Washington+98038&z=16
I'll be honest that I wasn't expecting miracles from an indoor antenna; and the $30 I spent on it I was spending almost as an experiment. We're selling our house & moving; which is why we cancelled cable. Right now I'm not in a position to run cables or setup an exterior outdoor antenna (Since we're selling the property & really disconnecting things & clearing it up) --- so an Indoor Antenna is my only option.
Is there any home-based remedy that would allow me to boost the signal reception on the antenna; perhaps allowing it to catch more stations?
Thanks!!
Thanks!!
mickey79
Although your'e pretty high in elevation, the hill to the NW is still almost a hundred feet higher. It also means the signal is coming at you pretty low on the horizon. The Tiger Mt stations are far higher, allowing you to get over a lot of those trees.
If you could get the antenna near a northern window, you might be able to pick up KIRO's translator. Towards the west, you could probably pickup KBTC 28, a PBS station. Of course, you could try an amp, like one from RatShack. If nothing works, at least you can take it back.
I did a survey just 50 yards west of the strip mall at 216th and Kent Kangley. He was right on the edge of the hill, but still had a lot of trees there, and it was a lot tougher than it looks.
Buy your next house in a better location! Shoot me an address and I'll let you know how it looks.
Dan
