Alright! We're really getting some traffic for lowly Wilmington...
Wayne-- I caught part of the Italy travel show--looked great. Also saw a portion of a show on a NJ beach talking about tiny stone figurines--also looked quite good.
Now, on to my question, related to my earlier query about signal bit-rate. I made the assumption that a higher bit rate should result in a better signal, or at least it could have less compression, so OTA HD, with a higher bit rate should look better than Dish (or other satellite)?
But, last night I again saw compression artifacts, especially in the scenes with grass in the Italy piece (shimmering), and in the shots of the ocean off the NJ shore (blockiness). I should add that I'm watching on a 58" Pioneer--maybe these effects are less visible on a small direct view set?
I have rarely (can't think of a time) seen compression artifacts in any Dish HD material (Showtime, HBO, CBS New York)--maybe I've just been lucky...
I'm sure this has been discussed ad nauseum in other threads--but in this case we can hear directly from the master of the electrons for the station...
What do you think is going on?
foxeng--points taken and understood. The part about number of viewers is especially true here, very very few getting OTA-DT let alone our meager HD. If cable started to carry the DT signal though, and it looked like crap, then there would be some action I suppose... I only call the engineers maybe once a month or so for status on HD feedthrough, or in the case of our NBC station, a status on transmitter activation. My approach is one of giving feedback on signal quality, and asking questions...
I'll bet our cable will carry local DT and HD before anyone even knows they could use an antenna--then all of a sudden viewership goes way up, then the stations will probably care a bit more...
Anyway, I'm looking forward to the Fall season of network programming, and finally being able to see it in HD........
What do you think is going on?foxeng--points taken and understood. The part about number of viewers is especially true here, very very few getting OTA-DT let alone our meager HD. If cable started to carry the DT signal though, and it looked like crap, then there would be some action I suppose... I only call the engineers maybe once a month or so for status on HD feedthrough, or in the case of our NBC station, a status on transmitter activation. My approach is one of giving feedback on signal quality, and asking questions...
Besides I get ABC SD out of Florence SC, ABC, CBS, PBS and FoxSD OTA and on Cable out of Raleigh area and HBO, SHO, DiscoveyHD and soon InHD on cable so I'm all set for HD viewing. WFXB-DT 43 Fox out of Marion SC I think is scheduled to go live Sept, 1st. We'll see Monday.
