Originally Posted by BasementBob
zductive:
(I'm not a fan of horizontal centers -- I don't care if the drivers are matched -- I prefer the fronts to be identical right down to the model number.)
In my basement I have three identical fronts that are good off axis, and four identical surrounds. There's a scene in Mission To Mars
chapter 11, where the mission commander's voice goes through each of the 4 surround speakers one at a time in a seamless arc, as well as the three front speakers, demonstrating that all 7 speakers get individual signals with Pro Logic IIx -- and there's a big timbre mismatch between my fronts and my surrounds.
For my smaller HT I'm thinking of buying 5 identical speakers (two monopole surrounds).
Wall/floor/ceiling reflections (and SBIR) can make speakers sound different (because the reflections don't reflect all the frequencies evenly resulting in colouration) -- but I'm wondering if there's something different about your speakers themselves, or perhaps a blown driver.
zductive:
I completely agree. Using pink noise, a timbre difference can be noted among my three identical front speakers but it is MUCH smaller than it was when I had the so-called matched and dedicated center speaker from the same company. Position in the room and relationship to other objects will affect any speakers but it always is best to start out with a match. BTW, I could further reduce the discrepancy with Meridian MRC but the change was small.
Kal
