So the traps at the front and back ceiling/wall junction aren't going to help as much as a bass trap in each of the front corners?
Depends... both cases are corner mounted panels and will work equally well as bass traps. And either may, or may not, also be useful for controlling SBIR and/or early reflections.
...he can get me a ton of free felt (more high tech then that but easy way to explain it as felt). Some of this stuff is extremely dense. I was wondering if this might be worth looking into.
No harm in looking into it I suppose... but you need to find out what the stuff is to make a determination. If its a medium density thermal insulation product, it probably has reasonably good acoustic absorption properties. Find out exactly what it is and look it up. Though I wouldn't settle for anything that didn't have good lab numbers... and good handling properties... as excellent materials in either semi-rigid fiberglass or rockwool are available in mosts markets for modest costs.
. This invitation is open to everyone here at AVS, I could really use the guidance and support.
