Originally Posted by pepar
If the ceiling is concrete and sloped, I don't think any suspended ceiling will change it acoustically where the bass is concerned. And speaking as someone who purposely built (20 years ago) a "media room" with a sloped ceiling, I would build the room rectangular the next time. It's not that is can't be treated properly to achieve good sound, it's just that a non-rectangular room makes it impossible to plan LF treatments in advance as all of the modeling software is for rectangular rooms.
Plan on a LOT of bass traps as you will not have the absorption that normally occurs with studded interior walls.
Thanks for your reply Pepar, I will finish the interior walls per normal standards.. framed, insulated, drywalled. As shown in the pictures, framing is already complete. Are you saying that without a finished ceiling I will need lots of bass traps or were you thinking all the walls were concrete and unfinished? I need to find out what my best ceiling options are.
Also, excuse my ignorance, what does LF mean?
Berk
This is a sound isolation problem, which cannot be substantially affected by acoustical treatment.
