Originally Posted by humyt
I'm planning to install some diffusors on the rear side walls of the room, just wondering if the layout of the diffusors needs to be symmetrical on both side walls?
Can I install say 3 pieces of 2' x 2' diffusors on the left side wall and 1 piece on the right side wall? This is due to an existing cabinet obstructing some parts of the rear right side wall.
Humyt - diffusion on the rear side walls does not need to be symetrical. I have a GIK D1 diffusor on the rear left side wall and a Skyline diffuser across from it on the right side wall and when one is removed there is very little sonic affect because just one is sufficient to attenuate flutter echo between the rear side walls. So, of course you should experiment but I would predict that having 2-3 on one rear side wall and only 1 on the opposite won't hurt things at all. Dr. Floyd Toole in his latest book shows various HT acoustical setups and there are examples of differing diffusion treatments across from each other (e.g. hemicylindrical, QRD diffusers.)
I agree with Ethan that diffusion on the back wall is where I put my first diffusers before the rear side walls. What kind of diffuser are you thinking of using because it's thickness (aka deepest well or cell depth) should be a minimum of 8" and work down to 300Hz and then use bass traps for <300Hz. One idea is to put a bass trap in the middle of the back wall with diffusers on either side of it, OR build a very deep diffuser and put bass traps beneath it for the floor/wall corner and back wall corners from floor-to-ceiling.
Clear as mud?
Your impressions?
