Pepar,
Are you using frictional absorption for the bass or something else, and how much? Those decay times look quite low, is there anything about the sound quality which you might refer to as stuffy or dry?
General question for anyone, can floor resonances of the overhead floor cause significant 10-30hz ringing (I've been thinking for a long time this might be my issue ) and if so can absorption be a practical solution other than redesigning the floor?
