AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Acoustical Treatments Master Thread
Acoustical Treatments Master Thread - Page 218
post #6511 of 9546
Originally Posted by Ethan Winer View Post
This video lets you hear what microphones pick up at the listening position in a room almost the exact same size as yours:
Hearing is Believing
--Ethan
Interesting.
Not sure that I can sense the increased spaciousness in the recording. The fully treated room is impressive sounding in the video (though a little too utilitarian looking for a home theater!). The untreated/fully treated contrast is instructive and probably even more extreme in person.
What was most interesting: Adding the diffusion to a room that already has good absorption really allowed the bass to be better defined -- which is usually something I associate with trapping rather than diffusion.
Maybe that's because your diffusers ALSO do some bass trapping. But it's interesting that that is what jumped out at me most.
post #6512 of 9546
^^^ Yes, the improvement in bass frequency response and ringing is due to the diffusors also working as bass traps. As for increased spaciousness, that's not so much what comes through in the video. It's more not hearing the boxy hollow type sound you'd usually have when recording music playing through loudspeakers.
--Ethan
post #6513 of 9546
Came across this brief but cool article on Microsoft's anechoic chamber:
http://gizmodo.com/5372268/microsoft...nd-goes-to-die
Trampoline floor sounds pretty cool!
post #6514 of 9546
Anyone ever use insulated sheathing similar to the stuff sold a Lowes or Home Depot? I guess it is made out of "Expanded Polystyrene" so Im not sure what the acoustic asorbtion properties would be. Im thinking about making my own acoustic panels out of it.
http://www.lowes.com/pd_15357-10477-...96_4294937087_
post #6515 of 9546
What is the difference between the yellow and pink fiberglass batting? I see the yellow go in the walls and pink go in the ceilings. This isn't the OC703 that I goes on after the drywall either.
post #6516 of 9546
I made these 3 diffusors about 3-4 years ago, should I cover them with fabric making them into "cubes" or should I follow the shape? the fabric is called Duck cloth, its cotton and you can see light through it but it is very stiff feeling so Im not sure how transparent it is. Its far from speaker grille cloth.
post #6517 of 9546
Mark,
If you want to fabric them and you have a fabric store nearby, take a look at 'broadcloth'.
I saw some yesterday a JoAnn and it looked like it might work good for your app.
Nice mix of transparency, workable structure, and available in lotsa colors.
post #6518 of 9546
http://www.bobgolds.com/AbsorptionCoefficients.htm is your friend.
post #6519 of 9546
Hi Mark,
You can always test any material by placing it in front of a speaker and performing near field tests on it. If it is more than -3dB, it won't work for your purposes. Best wishes!
post #6520 of 9546
I have a sample of GOM, Anchorage. I did the "breath" test and was a bit surprised... the cotton shirt I am wearing had less resistance...am I missing something?
post #6521 of 9546
Yep your test is right. You dont want to use that in front of speakers and it will diminish high frequency absorption of acoustic panels covered in it. Use 701 for example instead.
post #6522 of 9546
While Anchorage looks awesome, it doesn't have the acoustic rating that FR701 (I believe) does. If you received samples from Interface Fabrics they will have information on each fabric's properties. Anchorage doesn't claim any acoustic transparency according to the samples I have. It looks cool, but...
post #6523 of 9546
OK, good stuff thanks guys.....so use 701 or even speaker cloth on the false wall... However, does this mean that if I find something close to anchorage at a fabric store I can use it over 703 and base traps? Basically I am asking if I can be more liberal in my selection of fabrics on the areas other than the false wall......THANKS.
post #6524 of 9546
Adding cloth across the face will increase absorption. Because the pressure at the mouth of each well is different, there is significant airflow across the face of the fins. Adding cloth impedes this airflow.
Following the profile is better, but again there may be an increase in absorption due to the increase in surface roughness.
What the Cox and D'Antonio "bible" has to say...
They advise against cloth covering, but if you must use it, they suggest it be spaced at least one well width clear of the fin faces.
post #6525 of 9546
Hmmm, I would have made them a little more towards the pretty side had I known that.........I guess I'll featherfill ( thick primer) and paint the wood ones and fabric the absorbing one
post #6526 of 9546
FR701 is class "A" fire rated. Everything posted so far on Anchorage is correct. It's cool-looking and comes in some vivid colors, but FR701 is a better choice acoustically.
post #6527 of 9546
Alright, so I made some acoustical panels, but did not make a frame for each. I just wrapped each OC703 sheet in burlap. My original plan was to secure them to the walls with velcro that plan failed mightily.
I am looking for some suggestions on this dilemma. My two current options are:
1) use liquid nails to attach pegboard to the back of each panel and hang like a picture
2) use t-pins straight through the panels and into the wall
I am just looking for any opinions on these two choices or interested in hearing some better options. Thank you.
post #6528 of 9546
yeah you have to use pegboard or something to the back of the absorbing material then wrap the fabric over that and stick the velcro to the pegboard, not the fabric and then velcro is more than sufficient. You could still do this if the material was stuck using spray adhesive
post #6529 of 9546
BURLAP?? Really? Cripes, that's what we used to buy horse feed in ... I can't imagine. I'd say scrap the burlap and use GOM or something similar for your next go-around. And build frames.
post #6530 of 9546
Tooj,
I assume the panels are rather light and at least 1" thick and the backs are not a hard surface?
If so; the following suggestion (may seem simple and crude) worked for me:
Use a pencil to lightly trace out the perimeter outline of your panel in it's desired location onto your wall.
Hopefully you can locate at least one stud behind the drywall inside your outline. Then pound in some extra long finish nails ~2.5". Pound these in until the exposed length is slightly shorter than the thickness of your panels.
Next carefully position the panel in front of the nail heads, and then carefully press the panel to the wall, the exposed head of the finish nail should impale your panel into place, and you are done?
post #6531 of 9546
Thanks for the replies. cuzed2, this seems like the easiest choice. I'll give it a try sometime this week.
post #6532 of 9546
Good Luck - let us know if it worked
post #6533 of 9546
I (may) have the opportunity to purchase some Roxul AFB 1.5" for a great price. My plan would be to double it up to 3" for my acoustic panels.
I've looked at Bob Golds website and see that the numbers for 3" panels are roughly the same regardless of brand/manufacturer.
Is there any reason I would not want to use this particular product?
Rob
post #6534 of 9546
The Roxul is just fine and personally, my preference in terms of overall quality control from the factory.
Bryan
post #6535 of 9546
Bryan
Thanks Bryan.
On a side note, could I get away with 1.5" panels at the first/ceiling reflections and make up the difference in low absorption with corner chunks of the same material?
What I'm getting at is will there be a big audible difference with 1.5" panels vs. 2" panels at the first reflections, all else being equal?
post #6536 of 9546
Yes...that'll work just fine.
Not a huge difference.
post #6537 of 9546
Having difficult time finding 1" diffusors.......these are the only two I've found:
RPG Bad Panels which are not true diffusors
or
Auralex which are 1" plastic step wedges.
Are there other 1" thick diffusors that can be recommended?
post #6538 of 9546
or
One inch is not very deep for a diffusor ... or an absorber.
post #6539 of 9546
Right. Why do you want a 1" diffuser anyway?
post #6540 of 9546
I'm sure that it has something to do with aesthetics.
