I've been waiting for this topic to blow up for ages. Great info SMB and Dennis.
Surely Ethan's charts make some sort of an arugment for them?
How can the change be accounted for if the science behind what Dennis is saying is correct? there must be a middle ground that involves math beyond my capability?
Say I make an ottoman and put it between the seating position and the screen (about 3-4-5ft off the front wall, that would work as velocity absorber yes? that would work? I'd planned on filling it full with 703 equivalent polyester and covering in fabric.
Not sure if:
- increasing density from outside in would help?
- plutting a plastic membrane around it and then a bit more insulation (making is a pressure absorber) would help?
- having a free air space under it i.e. Have the bottom not solid and put it on little legs? (it'll have a solid top)
- Edit: what about a ring of peboard around it?
Not sure if:
Every room is different, and I have had the whip cracked over my head from you know who many times to prove it.
