hi everyone, i would like some opinions on my setup and if additional bass trapping will fix the issues im having. my room is 19' long x 15' wide x 8' high. i built everything myself, double drywall, greenglue, oc703 all around the room (42" high), front wall has it floor to ceiling and ceiling. my sub is located in the front right corner. i'm using anthem ARC room correction eq which sounds very good. my question though is in regards to adding corner bass traps to my front wall (superchunk method). basically, the sub sounds amazing when im sitting in the second row of my theater at the rear left corner. that is where i usually sit so everything sounds perfect. but if i move to the rear right side, bass is no where near as powerful. same goes for the primary LP which is closer to the screen. so it seems that bass energy is a lot more powerful at the rear of my theater near the walls, but also in the opposite side of sub placement. will corner bass traps to the front of the room help in any way? unfortunately i can't add anything to the rear of the room.
any suggestions/help?
thanks!
thanks!
. And yeah, sorry about not clarifying, that's exactly what I meant.
