Originally Posted by
smokarz
hey mtbdudex, thanks so much for sharing.
i noticed that you only wrapped the OC703 only, instead of the whole frame.
how did you keep the OC in the frame, so it doesn't fall out? i see 2 back panels support, but how about the front?
I've been thinking to make a separate thread on the DIY construction methods of hanging acoustic panels, currently none exist, I've searched AVS forum.
Just these for Fabric frames, which are integrated as part of the wall itself, not hanging and locatable to where only needed.
(these are great threads btw for those whole wall coverage methods)
Fabric Frames - GPowers ThreadAnother Fabric Frame Thread - Canvas Stretcher Bars
I'll start it later, and others can then add their methods there.
IMO, this "Master treatments" thread is more for the theory, science, and practical application for acoustics of your particular room situation/issue, not the DIY construction methods, that will clutter it too much.
Having separate DIY construction technique thread will keep that ready for others to grasp as well, this 100's pages thread can be overwhelming at times.
