AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Acoustical Treatments Master Thread
Acoustical Treatments Master Thread - Page 241
post #7201 of 9583
No problem.
post #7202 of 9583
Originally Posted by Ethan Winer View Post
I'm not saying to make your room totally dead. But there's a good amount of leeway with this, and generally more absorption leads to cleaner sound that is more realistic and lifelike.
--Ethan
Ethan:
You have stated that you use 38 traps in your living room. How big is each trap? Does a trap that goes from floor to ceiling in a corner count as a single trap or a combination of several?
For 1st reflection absorption in a home theater, you seem to recommend 2" rigid fiberglass. Dennis Erskine seems to recommend 1" on the grounds that 2" may be too deadening. Have I understood your position accurately? What is appropriate thickness for side reflection? This is where the art takes over from the science
perhaps. Or perhaps, your personal preference for a music listening room vice Dennis' for home theaters dictate different treatments? For example, you are no fan of dipole surrounds, but I am sure that Dennis would not want a good home theater without them.
My planned theater is rectangular (28' deep, 18' wide at screen, 16' wide at rear row, and 8.5' high ceilings) with a carpet floor. I will follow your advice on traps and 1st reflection treatment. Should I consider ceiling reflection absorption as well if my floor will be carpeted? (For what it is worth, I plan to use Atlantic Technology speakers and the manufacturer tells me that their 8200 THX model is designed to not have much significant vertical dispersion (ie. towards the ceiling))
Also, given my 28' long room, I am planning on putting a sub towards the rear vice front to put it closer to the listening position for greater effect. (I'll bass trap all corners). Is rear positioning OK or is the front preferred? Putting it in the front would mean requiring more power to drive it I think. Closer to seating would require less. Edit: I came across this article: http://www.realtraps.com/art_sub-placement.htm Will read it in full
post #7203 of 9583
Most rooms have 12 corners!
--Ethan
Ethan:
Do you mean 12 'edges'? I consider a corner to be where the walls/ceiling or walls/floor meet. So, 12 edges and 8 corners. Correct?
post #7204 of 9583
FSK is good for corner bass traps, but not for absorbers at reflection points. More here:
Density Report
--Ethan
Very useful. How and why does FRK affect absorption? It is such a thin layer that I thought it would have no effect! But, it does.
post #7205 of 9583
However, you could apply a new facing to what is now the front surface of the entire trap, which is really all those 2-inch edges. That not only reduces absorption at higher frequencies, but increases bass absorption too.
--Ethan
Why does adding facing INCREASE bass absorption?
post #7206 of 9583
Originally Posted by DIYHomeTheater View Post
Ethan:
Check out the photos and videos of his room on his site. Each trap is 2' X 4' except some at corners that are 2'x2' iirc.
I would be very surprised if Dennis at any time said 2'' is less good than 1'' for side panel thickness. That would contradict every measurement I have seen.
One might reasonably argue that sometimes diffusion is better than absorption but essentially never that one wants thinner absorption.
That's gonna be a nice space! You should consider starting a dedicated build thread with photos and details of the plan and progress. You'll get lots of good encouragement and maybe some good advice
about sub placement: Unless you are sitting next to a sub for tactile reasons, placement close or far is not the key. The key is how the sub interacts with the room modes. It is going to have to "fill" the room ("pressurize" it). Placement should be determined by where it sounds best when doing that. A quick search on the "crawling" method for sub placement will show you what I am talking about.
post #7207 of 9583
Ethan:
Yep.
post #7208 of 9583
FRK = Foil Reinforced Kraft paper (a.k.a. FSK = Foil Scrim Kraft paper, a.k.a. Scrim) - it has a thin layer of metallic foil (thin but not very porous).
post #7209 of 9583
Nathan:
Thanks. I recall reading that suggestion from Dennis Erskine on this thread. Check this post from him
It is post #6 on this thread.
My build thread is on my signature below. If you look at the voting button that I have established, the naysayers and cheering squad are about evenly split
post #7210 of 9583
Nathan:
I'm gonna say, in context, Dennis was talking about very large areas (full front wall and side wall all around up to ear level) being problematic (=leaving one open to absorbing too much). Stick with less coverage (eg, first reflection points) and thick panels at those points, for more reliable results.
Nice build thread! That's gonna be a great space.
The thread poll is pretty general, so it's not clear what the pro and con votes indicate....
post #7211 of 9583
Actually, I have 55 panels now.
The photos below are fairly recent, and Yes, I think I'm done!
The thicker the better, always. First reflections are mainly a mid/high frequency issue, but more bass trapping from using even thicker panels is always welcome. A panel thicker doesn't absorb more per se. Rather, it extends the same absorption to lower frequencies. So while even one inch thick is adequate, thicker is only better. And Yes, absorbing ceiling reflections is important too for most speaker types.
--Ethan
post #7212 of 9583
There are four corners where each wall meets another wall, four more where each wall meets the ceiling, and four more where each wall meets the floor. I'm talking about "normal" corners, not tri-corners where three boundaries meet. There are eight of those in a rectangle room.
--Ethan
post #7213 of 9583
The membrane vibrates when sound waves strike it, and the fiberglass the membrane is bonded to damps that vibration.
--Ethan
post #7214 of 9583
--Ethan
Thanks for your answers. Should the membrane be facing into the room or away from it? I would think the latter, right?
post #7215 of 9583
Into the room.
post #7216 of 9583
* Diffusion can be used on the front wall behind dipole speakers if the listener prefers more ambience, but wants to avoid the small-room boxy sound often caused by leaving those early reflections untreated.
--Ethan
I am confused. Dipoles are used as side and rear surrounds on the side and rear walls, respectively. Where is the 'front wall behind dipole speakers'?
post #7217 of 9583
Dipole speakers with mostly diffused front wall.
post #7218 of 9583
That's a sexy picture. What brand/model are those diffusers?
post #7219 of 9583
Auralex Acoustics: T’Fusors / Q’Fusors
post #7220 of 9583
Ethan:
How does one fashion a theater seat riser into a bass trap? Is it effective? Thanks for all the education that your website provides.
How would you modify your recommendations here for placing the LCR behind an acoustically transparent screen? Would you still toe-in the speakers?
post #7221 of 9583
Ethan:
Ethan W gave me advice on that for my riser, read here:
riser: Broadband bass trap
(Based upon Dennis E work/articles also.)
Is it effective? Yes - every bass trap helps.
post #7222 of 9583
Ethan:
Is an air gap recommended for the absorbers at the 1st reflection points, or can the absorber be mounted right against the wall? Thanks
Mtbdudex, Vinyl: Thanks for your responses.
Mtbdudex: What is the theory behind the design of risers as absorbers?
I found this article on risers as bass traps: http://www.audioholics.com/tweaks/do...ter-seat-riser. Elsewhere I found a critique of this design that essentially said that front facing holes are not quite as effective as 1/4" x 48" slits on the top of the decking.
post #7223 of 9583
Air gaps help increase the range of frequencies that are impacted by a trap -- typically a good thing when that means more bass is trapped -- hence the emphasis on "broad band" treatments...
post #7224 of 9583
Nathan:
So, you would recommend a gap for the 1st reflection points as well? If so, how much? What is the point of diminishing returns from a gap (if any)? Thanks
post #7225 of 9583
http://www.avsforum.com/avs-vb/showt...9#post20007129
Originally Posted by pgodden View Post
Yes I read your link, (Good Read Actually) I didnt catch on though about you doing it wrong initially, now I get it. Are the vents on the top absolutely required then? I would assume they are. I am now thinking 2 x 10 around the edges and 2 x 6 in the middle.
As Ethan W taught me, yes, for an effective broadband bass trap you need all those, as much as possible.
At first, I cut just a few 4" x 14", then more, and finally all along the perimeter.
There are some more advanced analysis that people have done where they know (via analysis and/or room measurement confirmation) a room mode will be an issue, and have turned the riser into a Helmholtz absorber via cutting specific width/length slit(s) in the riser....
I've read about that and visited a persons who's HT had that done for him.
However, for laypeople like us going the safe route with a broadband bass trap is the easiest and surest method.
post #7226 of 9583
[quote=Ethan Winer;20071042]Actually, I have 55 panels now.
--Ethan
Ethan:
With all this treatment what does the frequency response at your listening position look like?
post #7227 of 9583
Nathan:
Rule of thumb rather than science I can cite is the gap should not be thicker than the panel itself, and in practice is often 1 or 2 inches for a 2 to 4 inch thick panel.
That said, in ceiling installations people often leave an even bigger gap, and in corner straddling installations of course the gap is bigger, so there is no reason to shy away from using the space if you have it.
post #7228 of 9583
Given how terrible the LF response and ringing are in most rooms, I think mine is very good. This is an older plot, from before I added the last round of traps:
post #7229 of 9583
Ethan,
Have the 705 foil out in some areas. Would a light dusting of flat spray paint cause any problems? The reflection shows through the GOM 701 at some angles.
post #7230 of 9583
Originally Posted by Tireman1 View Post
Ethan,
I'd be concerned that the "dust" would come off and become airborne. I'm pretty sure that it will not adhere. And the foil will definitely flex.
Something to ponder.
Jeff
