AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Acoustical Treatments Master Thread
Acoustical Treatments Master Thread - Page 264
post #7891 of 9542
Originally Posted by nathan_h View Post
The diffusion I am talking about are the Auralex Q’Fusor (which they say is "derived from combining a standard quadratic residue sequence with some other mathematical techniques to create a profile that optimizes scattering surfaces.... down to about 800Hz").
"other mathematical techniques". hmm. sounds like marketing.
do they provide: polar responses, absorption coefficients, scattering coefficients, normalized diffusion coefficients, etc?
"and you have superior diffusion down to a frequency of around 800Hz!"
not sure how they are claiming 800hz "diffusion" with only 3" well depth. do they have a polar response @ 800hz?
have you toyed around with QRDude? if you are capable of some wood-work you would be much better off with constructing some schroeder QRD or PRDs. you can fine tune the design to your requirements (physical size, design freq, HF cut-off, etc)...and their performance is proven (and can be modeled with AMFG Reflex).
post #7892 of 9542
Auralex used to publish test data. It disappeared from their own web site a couple years ago, and from re-seller web sites some time in the past year.
post #7893 of 9542
right on.
if someone you know owns that product, ask if they could take measurements of it - and we could quickly model it into AMFG Reflex to gather an idea of the performance.
QRD/PRDs are tried and true. and the performance speaks for itself. you can also fine tune the design based on your requirements (design freq, period size, etc). if you're up for a challenge and have some work-working skills, maybe constructing your own would be something to look into
post #7894 of 9542
I like the DIY idea, though I admit: I'm better at rough carpentry (framing a wall) than fine finishing (I outsourced the mudding after I hung my own drywall).
post #7895 of 9542
Originally Posted by pepar View Post
FOH, you changed the meaning by dropping the full sentence. I know that there is some thinking "out there" that consider early lateral reflections beneficial, but localhost127's context was regarding not using a good tool for analyzing a problem and helping address it.
Jeff
I certainly meant nothing malicious by doing so. I merely wanted to reiterate that there are individuals that are adamant about taming 'early reflections'.
Since DE and I first disagreed wrt early mirror point energy (I suggested it be attenuated, he claimed not necessarily), I've continued extended subjective experimentations with all my treatments down in order to gain as much perspective as possible in the only room that matters to me. I've got Toole's Sound Reproduction, Everest's Handbook, I've read a great deal on Gearslutz and elsewhere,... I'm experimenting with several different mains, and mains optimization techniques. I like envelopment, spaciousness, however I value clarity and image specificity as well.
I've found localhost's posts very solid and quite enlightening wrt small room acoustics. Just as localhost's post have been very helpful to many, so has several other contributors here, and for that I'm grateful. Now retired, I've entered into this deep foray back into home audio because I decided to re-vamp the modest family AV room from bottom to top. I've always had small dedicated mixing/editing/mastering rig and the primary family system has been quite mid-fi in quality. For the family room, a new big IB, new mains, surrounds, front end source and pre/pro, and ultimately,..strong acoustic properties are all immediate priorities. This, in a non dedicated space has proved to be quite a challenge.
Anyway, I changed the quote to suit my point I wanted to make, that's all. I certainly didn't want to piss anyone off, as I'll likely be in need of more specific advice, from many of you, when the time comes
post #7896 of 9542
post #7897 of 9542
FOH, you'll like your IB sub, some guys here have dual line array 4 x 18FI (penngray is one in my memory). My modest 4x15 single line array never ceases to amaze me.
post #7898 of 9542
post #7899 of 9542
I've very much enjoyed reading about your room in general, and more specifically your IB and various acoustical treatments. I do have a question for you or anyone; I've seen different acoustical cotton products and I really like the idea of trying them in a couple applications. I've got a great source for rigid fiberglass, however I looking for a good source for acoustical cotton,..any help in this regard?
post #7900 of 9542
... bookmarked yet another of your posts!
Jeff
post #7901 of 9542
I've used this as a source for acoustical cotton, http://www.acoustimac.com/index.php/...oinsul422.html
From another post I made
Well looking at the data it sure seems to have much better low freq absorption characteristics....
Sound Absorption Coefficients (1/3 Octave Band Center Frequencies. HZ)
Hz
100 125 250 500 1000 2000 4000
2" Thickness 0.38 .39 .63 1.18 1.11 1.06 1.09
An even greener alternative to cotton insulation:
Cotton insulation works as well as its fiberglass counterparts, however this material can be prone to mold and is not as biodegradable and recyclable as cellulose which is made from recycled newspapers and cardboard products.
Better Performance than Fiberglass!
Oh yes, it's true! This cellulose based insulation has even higher absorption coefficients than our standard insulation material, so not only is it more eco-friendly, it also outperforms its fiberglass and mineral wool counterparts hands down.
Freq 125 HZ 250 HZ 500 HZ 1000 HZ 2000 HZ 4000 HZ NRC
OC-703 (2") 0.17 0.86 1.14 1.07 1.02 0.98 1.00
OC-705 0.16 0.71 1.02 1.01 0.99 0.99 0.95
post #7902 of 9542
... Bookmarked yet another of your posts!
Jeff
+1, +2, +3, ....:d
post #7903 of 9542
Thank you sir.
post #7904 of 9542
Is there a reason you want acoustical cotton over rigid fiberglass? If because of the air quality or "itchy stuff" stuff then check out Knauf rigid fiberglass.
post #7905 of 9542
Cool, I'm down the road from the Knauf plant
post #7906 of 9542
dirt cheap deep pink fluffy corner traps (although they need to be fluffed out a bit better). and the plastic will reflect some highs back into the room.
post #7907 of 9542
Nice localhost!
Makes me wonder about the performance of the above mentioned big rolls of insulation, merely set into a room corners etc. Anyone familiar with such a temporary approach? It'd be interesting to know how well they perform. I realize they are bound a bit too tight, however I'd think they'd work to some degree.
You know how one brings a bottle of wine as one visits an acquaintance? Well, during these multi-sub, multi enthusiast subwoofer shootouts that are hosted on occasion, instead of wine, each attendee should bring a huge roll of insulation as a party favor. Strategically place them around the room, then upon completion of the GTG, the host gets to increase their attic insulation significantly
post #7908 of 9542
Nice localhost!
Rolls of fiberglass work. Kind of hard to make look nice though. Here is a room I found on you tube
http://www.youtube.com/watch?v=DsJVHcb9k4c
post #7909 of 9542
such a waste when compressed. i made those 6 pillows with a little over 1roll of the smaller rolls of insulation (!). the point of compressed is to make the traps very thick of low GFR - and to cover as much sq area as possible. leaving them compressed somewhat defeats all of those purposes. it looks like that guy is using the larger (standard) rolls of r30 insulation. i bet he could cover all corners with 48" faced (16"+ thick) fluffy traps in plastic wrapping with about 1/3rd of the rolls he has in that room stacked.
post #7910 of 9542
I think you guys might really enjoy this video done by Zalan Schuster. I appreciate not everyone can speak Slovakian but it has some audio demonstrations starting around 3:35. Before hand he has some nice before and after test graphs of the room.
post #7911 of 9542
Is that a ... railroad car???
post #7912 of 9542
ive read some say that maintaining early reflections (in small acoustical spaces) offers more "spaciousness" or other characteristics. my question is, do large rooms not offer such "spaciousness"? large rooms do not have early-reflections, so why is it that in larger rooms we do not see an effort to induce early reflections towards the listening position - if they are indeed so critical to spaciousness?
something fundamental that i think is constantly missed regarding attenuating early reflections is that you are changing the brain's perception of how large the room is. the longer the distance between the original signal and the first loud specular reflection, the larger the perceived room size. one can essentially "cheat" by artificially delaying this first specular reflection (in the time-domain) to make the room sound larger. this logic is taken to the extreme with anechoic spaces - where the first loud specular reflection after the original source is an infinite time away - making the room sound infinitely large. of course, our brains do not prefer this - but the brain has never been put in such a situation in the real world, anyways...as such an event (no reflections from any boundaries) does not exist in the real world that we would be constantly subjected to.
also perhaps what goes unnoticed is that in music, the `room' that the music was recorded in is already present on the recording. early reflections in your listening space mask the sound of the room that the music was originally recorded in. you are hearing the reflections of your small acoustical space's boundaries earlier than the reflections from the room the music was recorded in - and therefore are 'hearing' your room instead of being mentally transported into the room of the recording.
this is why in a control room, the ISD-gap needs to be a few ms longer than the ISD of the room of which the music was recorded in. otherwise, the control room itself is masking the sound of the recording. the design for making the control room as neutral as possible can be directly related to critical listening rooms - if that is one's goal.
have you anything to report regarding your own personal experimentation, FOH?
post #7913 of 9542
Originally Posted by localhost127 View Post
ive read some say that maintaining early reflections (in small acoustical spaces) offers more "spaciousness" or other characteristics. my question is, do large rooms not offer such "spaciousness"? large rooms do not have early-reflections, so why is it that in larger rooms we do not see an effort to induce early reflections towards the listening position - if they are indeed so critical to spaciousness??
Aren't large rooms already by definition spacious? They wouldn't need to simulate largeness - they already are large.
post #7914 of 9542
The difference lies in the delta between arrival times and the decay of the reflected sound over time/distance.
post #7915 of 9542
my question was, if we are attempting to create 'spaciousness' in a small acoustical space (emulating a 'larger room'), then why do we inhibit early-reflections which are not present in larger rooms (by definition).
post #7916 of 9542
im just trying to understand what the ideal specular response is when one induces (or maintains) early reflections in a small acoustical space - so i could recreate for my own personal testing.
can you elude any further to what the delta times should be?
i already have these answers for RFZ/LEDE room models, but for my own testing i'd need to know what the ideal specular response should look like when incorporating early-reflections, so i can verify that i am testing properly - for comparison. thank you,
post #7917 of 9542
In theory - I have however gotten great results with corner stacking of these Cellulose bundles ($8 each- home depot) - has greatly reduced low end energy /bass decay in that corner (concrete)
- don't mind the mess -back of room is currently experimental center
I am now trying out different combos of 4 bass traps (made from OFI-48)
I have great low-end response now in room (34L/12.5w/7.5h with large opening in back ) but always tweaking
post #7918 of 9542
if you have enough of those Cellulose bundles lying around, may i suggest an experiment? stack them floor to ceiling like you have now, but stack them 2 units wide (you'll have to bring them out from the corner a bit to be able to fit 2x bundles wide - and they'll be straddling the corner)...but bringing them further away from the boundary and making a wider trap could really increase effectiveness.
may be a fun experiment if you're interested
post #7919 of 9542
Yes - I found that as well as straddling my DYI bass Traps diagonally - floor to ceiling in that same corner all had very similiar results
I will probally end up doing corner chunks (fabric covered) and nicely made traps covering the back wall for nice compromise between performance and aesthetics
post #7920 of 9542
I Have Some Queries here in India.
My Room size is 25*15.5*9.5(height)(Sizes in feet).It's a basement room.It's
a corner part of basement i.e with no adjoining basement on 3 sides.My Room
is Bricked from all 4 sides.I have a lot of echo in my room.
I am getting Fibre Glass Sheets 2*3 feet
48kg/m3 in 2,3,4inch.
Q1 Which is preferred?
Q2 For Making Membreane Bass Traps, (as explained in Ethan Winers Page),Can I Use Laminate(For Decorative) on top of plywood?
Q3 Can sheetrock be used over fibreglass for more effectiveness?Can Someone Explain it's use? and How To Place it?
Q4 What Should Be Done to absorb all lower frequencies?
like changing Thickness of fibre glass, changing the air gap, placing the top plywood with some angle?
Q5 Should the plasterd bricked walls be first covered with plywood for placing glass wool or can be directly placed on the wall for medium and high frequencies absorbing?
Please Help Me With This and help me build my Theatre Room?
Thanks In advance
