A couple of minor points: diffusors do not affect RT60 in the manner described nor will they have any impact on standing waves.
While vertical strips can create a moderate amount of diffusion, you cannot cover all the early reflection points to all seats effectively. In the 'ear level' scenario, you do have 'stuff' bouncing around above your head; but, if you watch your angle of incidence against where your speakers are placed (height), you've covered all the bases within the curve. This is also a much more effective method with rows of seating since you'll have more people close to the side/back walls than in a two channel, single seat of excellence environment.
In multi-channel...no bad seats not one good seat.
Dennis,
In the deciding the height for the insulation on side and rear wall where should the refelection point for the front speakers to the listening positions be with respect to the top of the insulation? Above, at, or below? Which elememt of a 3way speaker to use as the reference?
Dale
