Understood. My point about multiple subs was not for increasing bass levels, but as an alternative to using passive bass traps, presumably to reduce bass lumpiness caused by room modes. If the system is not plagued by such uneven response, then no need.Originally Posted by rnrgagne
At this point I'm not thinking mulitple subs, my mains are more than adequate for music and are crossed at 40hz. I have a little Seismic 12 which is surprisingly visceral on LFE, and adequate enough for what's below my crossover points. Crossing over my mains that low is kind of like using multiple subs already, and I use Audyssey XT32 Pro, so there's a lot of help in that department. It does a great job in a less than stellar room.
If there's some significant energy returning from that portal, then yes, killing it would be useful. Best to determine the spectrum of that before deciding on the solution.My room's main issue is there's an 8' opening on the left side of the MLP into a foyer that houses a curved wall/staircase which acts like a parabolic mike and I'd like to put something in there.
Yes, the pix show standard walls. Undoubtedly sound would benefit from some appropriate diffusion and absorption. I realize you are trying to minimize visual impact, but a large percentage of the surface will need coverage, more than the wicker baskets will address. I have found the standard GOM covered panels, in the right colors to blend with the walls (or ceiling), are not visually overbearing at all, and can be very effective in taming a live room.Plus the room is actually pretty baren, it needs some "accessorizing" including HF treatments, as it can get out of hand at higher volumes.
