Originally Posted by pqfan
Okay, this is my understanding:
720p tends to give better results with fast moving images. Hence it is was selected by ESPN to give best image quality for sports programming.
1080i shows more detail, which should look better with slower images that contain more detail. This would include most movies.
Obviously, no one choice is best for all content. Ideally a network would change their broadcast method to match each show but no one does that and it is probably not practical.
there is also the difference with useing the tv tuner vs a cable or sat box and what out put the cable / sat box is set to.
