AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Chicago, IL - Comcast
Chicago, IL - Comcast - Page 344
post #10291 of 10595
Originally Posted by Spiderman865 View Post
Hopefully this means more HD coming after the complete analog shut down.
Hopefully this means they will bring back all the Premium HD channels they cut last year.
(in my area they got rid of several HBO and Showtime channels to make room for overly-compressed, barely HD versions of BBCA and DIY)
post #10292 of 10595
Originally Posted by illiniwek84 View Post
We just noticed something in the past week or so. With the digital set top box (the kind without DVR, no display, and you can see the Motorola CableCard through the top vents), the SD channels are getting clipped where bottom and top are being cut off (like ESPN crawl at the bottom). HD channels work fine. I tried cycling through the set up of the Panasonic Viera plasma we have for zoom, 4:3, full, etc. and even in 4:3 mode, the video is clipped. Anyone else seen this?
With the box off, hit MENU to get the setup screen. Double-check the settings, especially for 4:3 override. It should normally be 480i to pass SD as-is.
post #10293 of 10595
Notice on my March Bill:
Effective 4/4/12, these channels will be added to
Digital Preferred: Smithsonian Channel (chl. 153);
BBC World News (chl. 154); CNBC World (chl. 155);
and Inspiration Network (chl. 157).
NOTE: CNBC World will also continue to air on its
current Digital Preferred channel 178 until 4/10/12.
Effective April 5, 2012, Spike TV will no longer be available on
Digital Economy. Spike TV will still be available on Digital
Starter. H2, formerly History International, will be added to
Digital Economy.
Effective April 26, 2012, Tele5, a general entertainment channel,
will be added to the Polish Super Pack, replacing TVP Info.
post #10294 of 10595
Cool. I've been waiting for Smithsonian for a long time. From the channel number, it appears to be SD only?
BBCWN was expected, as that was part of the deal to move BBCA to Starter.
post #10295 of 10595
My guess is SD only which is kind crazy since Smithsonian HD has been available on-demand for quite some time. While SD additions are OK, I was hoping for HD additions with the elimination of analog basic.
post #10296 of 10595
Thanks, Andy. I also happened to stumble across the comcast channel with instructions. Actually, I had to select TV capabilities that 480i was supported. I never saw this menu before and not sure what changed. Oh well. It's fine now.
post #10297 of 10595
Any news on FSC-HD or FSC+?
post #10298 of 10595
RCN has CLTV HD will comcast add any time soon?
post #10299 of 10595
Is HDNet available on Comcast in the Chicago area?
post #10300 of 10595
You'll need to be more specific about the location, Mikey Man.  Which municipality, or if you're thinking about a spot inside Chicago, what part of the city?
It is available in Chicago Area 2, but HDNet Movies is not.  Area 3 should be the same.  I can't say about areas 1, 4, and 5, nor about any of the suburbs.
post #10301 of 10595
HD Movies is NOT (going to be) available on ANY CC system; their last contract with Cuban was ONLY for HD Net on Preferred. If you look here, it's NEVER been shown as available:
http://www.avsforum.com/avs-vb/showthread.php?t=1058081
On the few systems that did have HD Movies, that CC took over, (like the Insight systems, etc.) it was removed right after the takeover was complete - while HD Net remained on...
post #10302 of 10595
HDNet is here in Schaumburg and probably most of the N and NW suburbs fed by the Mt Prospect super-headend.
post #10303 of 10595
You'll need to be more specific about the location, Mikey Man.* Which municipality, or if you're thinking about a spot inside Chicago, what part of the city?
It is available in Chicago Area 2, but HDNet Movies is not.* Area 3 should be the same.* I can't say about areas 1, 4, and 5, nor about any of the suburbs.
I'm in the 'burbs, Alsip area.
There's some cool concerts on HDNet. I don't see the channel listed in my zone, but it's some other areas?
post #10304 of 10595
HDNet is rebranding itself as AXS TV this summer:
http://www.hd.net/press_articles/axs-q-and-a/
post #10305 of 10595
Anyone have any info on the new streampix service? Is there going to be an app for devices like the iPad? Or is it pretty muck the same as on demand? Couldn't really tell anything from the Comcast web site.
post #10306 of 10595
It's both a premium OnDemand channel (if you use a cable box), or streaming on a device. I think Comcast is working on apps for various devices that should be out soon, if they are not already available.
post #10307 of 10595
No app out for the iPad yet other than the xfinity app which has been available for awhile. I am wondering if the content available from Streampix differs from what is available On Demand. Comcast is certainly not providing a lot of information.
post #10308 of 10595
There isn't a separate Streampix app, but it's in the Xfinity TV app. I don't know if on the iPad it's listed different, but on the iPhone version, it's under Play Now > Networks > Streampix
post #10309 of 10595
I'm in Lincoln park with 2 DCX3400's boxes and neither of them changed their time last night. Anyone else seeing this?
Getting nowhere fast with Comcast. I can see in diagnostic menu that my DST entry date and ext date are both 2011..
Edit: After 30 minutes talking to someone and texting some friends to see what their boxes are saying (none are right), the tech is now saying all of comcast is wrong. Who knows if that is accurate.
post #10310 of 10595
Off the McHenry Headend up here by the IL-WI line, the time on my DCX3400 updated on it's own to DST.
Not a Comcast-wide problem, by any means.
post #10311 of 10595
Thats for confirming. I kind of figured as much. I do know at least one other person down the street from me with the same issue.. not sure if its sporatic or my area. I'm done caring for the day, the weather is too nice! haha This all stemmed from my wife not wanting to miss Oprah tonight on the DVR. I'll just set a manual recording around it in case the time updates.
post #10312 of 10595
Yep. That is where it is at on the iPad app as well. Never looked under networks before. Thanks.
post #10313 of 10595
Is there any way to access Streampix, or any value to it, if one doesn't have a smartphone?  Apparently one of its functions is to stream video to the customer's television, which sounds no different from On Demand except for possibly a different set of selections.  But I couldn't figure anything out from what I found on comcast.com.
post #10314 of 10595
Is there any way to access Streampix, or any value to it, if one doesn't have a smartphone?* Apparently one of its functions is to stream video to the customer's television, which sounds no different from On Demand except for possibly a different set of selections.* But I couldn't figure anything out from what I found on comcast.com.
It's in On Demand. Under premium networks, I believe. It'll be listed as Xfinity Streampix
post #10315 of 10595
Thank you.  I'd never have thought of looking for it there.
The funny thing is that the reason I posted here rather than phoning Comcast was that I expected a heavily technical answer that a phone rep might not have been able to give me, or not been able to convey correctly.
post #10316 of 10595
It doesn't look like there's anything decent under the StreamPix selection. It looks like old stuff, that most would probably not be looking to watch again, IMO.
post #10317 of 10595
There is something weird going on with CLTV this morning. It was dead for a bit, and now is showing the feed from different channels. It started as some informercial, then aired Bloomberg for a few minutes. Then Discovery Fit and Health, then Nicktoons, and now NatGeoWild.
A look at the diagnostics show the same frequency and subchannel as always, and these channels are normally on completely different frequencies, and still there on those originals.
post #10318 of 10595
Got a message that my tv isn't ready for comcast digital enhancements when watching using my tivo. Tv only works ok, do i need a cable card now even for the basic? If so this is bad.
post #10319 of 10595
Anyone else having any problems with On-Demand? Tried watching On-Demand and a message came up saying to unplug our box for a minute and then try again. The same message was on all 3 of our boxes. I unplugged all of them and plugged them back in a few hours ago and On-Demand isn't working on any of them now.
post #10320 of 10595
Pretty sure you're going to need a CableCARD, unless you want to tune to the QAM channel. Last I checked, the TiVo doesn't have any way to manually map QAM channels to those listed in the guide data. So as an example, if you're tuning to cable channel 2 for WBBM, and you don't have a CableCARD, you're getting the analog feed - which is going away in early April.
You say your TV works fine by itself. Does your TV have a DTA or a box?
