Originally posted by Spam
I recently had Comcast installed and am noticing that I have many lip-synch problems. More-so with channels 187-191, but I also notice slight lip-synch problems with other channels once in a while. Sometimes it's worse than other times. Have others also noticed this? Or is this possibly an issue on my end? I searched all of the other posts and have seen that there have been issues with "video-stutter" (WFLD and CBS), but I wanted to confirm that others are also having lip-synch issues. Thanks.
How is your audio and video connected? Are you using an A\\V receiver for switching? I'm wondering if you have, for example, the component video going to a switcher and the audio directly to the TV. Perhaps a device in the path is causing the delay.
I have noticed that the digital broadcast lags behind the analog version of the same broadcast. Maybe you are using different feeds for the audio and video signals.
I have only occasionally experience this problem, but have not seen it recently.
Mike K.
