AVS › AVS Forum › HDTV › Local HDTV Info and Reception › El Paso, TX - HDTV
El Paso, TX - HDTV - Page 9
post #241 of 1588
tonight (friday) the guide was good to 3 am
post #242 of 1588
Noticed a blurb in the paper this weekend that KRWG is building a new tranmission tower on "A" mountain. They are currently off the air (not sure why) but when the new tower is completed, they will transmit their DTV/HD signals from there.
The new tower will replace several others that the FCC apparently wants removed.
post #243 of 1588
Anyone else get bubkis on NBC tonight? (9/27) Had "My Name is Earl" to record and got 20 minutes of pixelleated dropouts....
Better question, anyone weasled a HD Waiver out of NBC in El Paso???
post #244 of 1588
Londo, what is the HD waiver for? Is it to get the HD signal from another station when DirecTV carries the local HD channels for the top 10 DMAs?
post #245 of 1588
c_hernandez, that's basically correct. THere's a pretty good explanation on KVIA's website at http://www.kvia.com/Global/story.asp?S=1580429 -- scroll down to "The Satellite Home Viewer Improvement Act". Sounds like if they think you should be getting their signal they will deny it, so Londo's use of the word "weasled" is pretty much spot-on.
post #246 of 1588
How about the WB? We have no local station, in fact on DirecTV I get a Florida station. Do we call DirecTV? I would love to see the LotR in HD. They seem to play each movie every year.
post #247 of 1588
I have finally found some time to mess with setting up my antenna and I can get everything except CBS (KDBC). What is with this station? when I try to manually add the channel (uhf ch 18) the signal bounces from max to zero, back and forth.
Is anyone getting them OTA right now? Its almost like the station management doesn't care if they stay up on HD or not.
Thanks for any info you may have!
EDIT: I sent an email to the general manager of the station and actually got a call within 30 minutes of sending it. WOW!
After speaking with him about my particular situation, it seems that I may have terrain blocking the signal. I am in the NE part of town close to the mountain. He offered that I consider TW or Direct TV to get his station on HD, I asked him to move the antenna higher on the mountain. We both laughed as neither one of those would happen.
Just thought I'd post the results.
post #248 of 1588
Yeah well the Denver/JAX game was on HD channel 1303 in SD. At least the sound wasn't distorted.
post #249 of 1588
the denver/jax game was not in hd only 3 games a week on cbs taht wasnt one of them
post #250 of 1588
This is my first post. After reviewing this forum for the last month and finally fealing optimistic about my chances for off-air HD in Cruces, I decided to try the silver sensor antenna. I live about 0.5 miles NE of the I-25--70 intersection, off Del Rey. Much to my surprise, I was immeidately able to pick up ABC, NBC, CBS, and FOX, in addition to one of the Spanish channels (Sweet!). What a difference!
It was pretty tricky finding the right direction for the antenna, but it seems to work best pointing just W of the Organs. The signal strength meter on my Samsung SIR-TS360 was ranging between 45--75%, but usually near 45%. I decided to try adding a $30 RadioShack amp today, which improved the signal strength to consistently over 65%.
I can't pick up the local PBS station and was wondering if anyone else in Cruces was receiving their broadcast.
post #251 of 1588
It sounds like you are getting "Multipathing" on KDBC's signal. Try turning your antenna to see if the signal strength quits jumping. Or you may have to reposition the antenna.
post #252 of 1588
Another Silver Sensor story! How/where do you have it mounted? I live to the west of you, just to the nw of 25/70 intersection and use a Channel Master outdoor antenna with a preamp. I'm getting all stations with signal strength from 65-85%.
KRWG is currently off the air. I talked to their enigneer a few weeks ago and he was having trouble with the multiplexor. They are building a new antenna on A Mountain and will relocate their transmitter there. I assume he is working on the multiplexor problem. Seems most of the DTV/HD stuff is specially built and it takes a while to get parts and replacements.
post #253 of 1588
The (small, but mighty) silver sensor is on a ledge (~ 10 ft high) that runs around my living room, directly above my TV. I still can't believe the difference. Also impressive is the impact of the 10db amplifier from RadioShack. I almost completely lose the signal when the amp is off.
post #254 of 1588
Directv does not have any El Paso stations in HD. They maybe using the HD signal for uplink, but everything is in SD when it gets to the receiver. I know Directv is expanding it's local HD offerings, but it going to be rolled out over a few years starting with the bigger cities.
post #255 of 1588
coebra what amp are you using from radio shack? i am having trouble getting all the channels except fox and i live off of del ray. Im also using the silver sensor
post #256 of 1588
I'm using the Bi-Directional Cable-TV amplifier (model # 15-2505). It works well and gives me more flexibility with antenna placement.
Good luck!
post #257 of 1588
im gonna try that amp. Im able to get fox fine and i can get cbs, but have some dropouts from a weak signal hopefully amp will help me out.
post #258 of 1588
krwg hd is back ota for las cruces viewers
post #259 of 1588
I have not been able to get a clear picture from any of the KRWG broadcasts. The image is highly pixelated and broken up eventhough the signal strength meter reads pretty high (up to 76%). Is anyone else in town able to see them clearly?
post #260 of 1588
try moving your antenna to a different place. I was having the same problem but moved my antenna and now its fine
post #261 of 1588
Has anybody else experienced a loss of audio on KTSM? Last weekend and this, the first quarter of the footall game has no audio. Was it still working on SD?
post #262 of 1588
Yes, I've had the same happen. KVIA is also getting dropouts. Seems ABC hardly shows any football games in HD where KFOX, KDBC and KTSM do. What's up with that?
post #263 of 1588
its just the abc network they only do monday night football in hd and no college games
post #264 of 1588
Too bad. KVIA was the last to get their DTV signal to Las Cruces, happened the day before the deadline. It appears to me that ABC didn't plan for the transition and is taking the cheap route anywhere they can, as evidenced of having to get their parts from the UK when their equipment broke after only 3 days of transmitting at full power! I guess when MFN is done next year, they'll really save on money!!!
post #265 of 1588
Oh no! Fox is down for the count...Any idea for how long?
post #266 of 1588
One good thing is FOX and KDBC seem to be on the ball more than the others. Hopefully they will have it going today!
post #267 of 1588
comcast has added ktsm hd to its lineup and now has pbs fox and nbc hd not cbs or abc yet though
post #268 of 1588
What package do you have and what is the cost?
post #269 of 1588
i just have basic cable the hd locals are for free you have to pay for espn and discovery hd just do a channel search and you should be able to get pbs, fox and nbc hd
post #270 of 1588
On Comcast? Free? Amazing!
