AVS › AVS Forum › HDTV › Local HDTV Info and Reception › El Paso, TX - HDTV
El Paso, TX - HDTV - Page 3
post #61 of 1588
Hi boomerbubba, yes Time Warner Cable does have a HD package in El Paso. I have the Time Warner Cable HD package and can say its actually pretty nice. They offer two HD cable boxes, Scientific Atlantic Explorer Digital Cable boxes: 3250HD and 8000HD. The 8000HD box has DVR service which works even with HD, this is what I got and is extremely nice. The 3250HD works very nice but it does not have DVR.
The current HD channels in the El Paso TWC-HD package are:
HBO HD - East
HBO HD - West
Showtime HD - East
Showtime HD - West
KTSM HD - NBC
KDBC HD - CBS
Discovery HD
TNT HD
In Demand HD1
In Demand HD2
Fox Sports Network HD
HDNet
HDNet Movies
ESPN HD
KCOS HD - PBS
I wish they would add the rest of the local HD channels, though I think I heard that they will be doing that soon. Another nice feature I wish they would have is a OTA feature that would allow you to find your OTA channels with an antenna.
One bad note about Time Warner Cable is that a lot of their cable installers, don't know how to set up the HD receivers properly when they put them in peoples homes here in El Paso. The cable receivers have to be set up to work in 1080i or 720p when they are initially installed, otherwise they will only show programming in 480i. It happend to me twice, where the installer installed the receiver and left it on 480i only. I had to go to Scientific Atlantic's website to get an online manual for the 8000HD box to set up the box properly myself to work in 1080i.
But other than the installation-set up problem, TWC HD-DVR seems to be a good deal for me here in West Texas.
post #62 of 1588
boomerbubba,
TW does offer digital cable but think of it just like you would SAT. It is a digital signal but not always HD. I don't have cable but I have friends that do and from what they say it just gives you more channels, with the TW box of course. This thread is for local HDTV info and reception, to me that means OTA. There probably are threads about TW here.
post #63 of 1588
I am on the west side, by Franklin Hills, and all I receive is CBS.
I am using a Philips indoor antenna, should I get an external one?
I just installed my receiver, and the Steelers vs Jets game looked great
How are you guys pointing your antennas?
post #64 of 1588
jfe,
I had a big long reply for you but go to antennaweb (dot) org. It wouldn't let me post the URL and it deleted what I had typed. if you go there and put in your adress it will give you an azimuth to help point your antenna.
MKZTG
post #65 of 1588
The philips indoor is no good. Go with the silver sensor you can get one at sears.
post #66 of 1588
I will give the silver sensor a shot
Although both of them looks the same
CBS is gone for me, and Fox looks great.
Weird
post #67 of 1588
Anyone else out there have HD on TWC in El Paso?
I'm a new subscriber to HD and I am pretty happy with the available channel lineup. That being said, I am wondering if anyone has any information on when/if our local TWC will be picking up FOX and/or ABC. Also, anyone know why our FOXSN HD channel is always off the air?.
Anyway, hopefully this will get the ball rolling, and there are others of you out there!
post #68 of 1588
This thread is for local HDTV info and reception, to me that means OTA. There probably are threads about TW here. [/b]
FYI, I've started a new thread (there was none) for TWC customers in El Paso. Please drop by!
post #69 of 1588
What is going on with ABC 7 and their HD feed? Everytime I tune into a show that is broadcast in HD all I get is the standard black bar feed with no HD. Are they forgetting to hit the "switch?" CBS 4 shows HD all the time for their prime time listings.
Any info?
Also, any word on when they will be broadcasting at full power?
thanks,
post #70 of 1588
For future reference, "HDTV" threads are for discussion of OTA and cable in the local area.
If you guys want separate threads, we can do that, but I'd make sure you have enough activity or both threads could just die on the vine.
post #71 of 1588
Fox HD OTA was down for a few days about a month ago but they are up right now. Check to make sure you don't need to fine tune your antenna azimuth, thats what I had to do to get all the networks in.
MKZTG
post #72 of 1588
danilope28,
I have actually emailed KVIA and I can't get anyone to respond. I'm not sure if they just don't care or don't know how to fix it. A response would be nice though.
I am having audio problems with KTSM (NBC) is anyone else? The problem is, I will get a "blurb" of audio when I first change to the channel and then nothing. All the other channels are just fine.
MKZTG
danilope28 said:
ABC 7?
Any info?
thanks,
post #73 of 1588
I started the thread under the assumption that it was S.O.P. to do so. What you say makes perfect sense, and I don't think the volume is great enough to need or support separate threads either.
post #74 of 1588
Well, the silver sensor didn't work too well for me
I had to buy a huge Terk TV55 antenna, and that does seem to work
post #75 of 1588
FOXSN HD does show games and programming in HD..but I've only seen them do Houston Astros baseball games and a couple other shows back in the summer, an HD show sometimes comes out once in a while..but mainly it's just an all black-screen channel.
As for FOXHD 14 or ABCHD 7, I'm not sure when they'll add these two channels? Hopefully they will add them soon because that would make the HD package a lot better.
post #76 of 1588
You actually got the Terk TV55 to work for you? Thats awesome, I heard that many people have problems with that antenna picking up stations..but thats good that you got that one to work for you.
post #77 of 1588
Originally posted by raid98 FOXSN HD does show games and programming in HD..but I've only seen them do Houston Astros baseball games and a couple other shows back in the summer, an HD show sometimes comes out once in a while..but mainly it's just an all black-screen channel.
Yeah, I was assuming it wasn't working, but there just isn't much scheduled. If anyone is interested I managed to track down their schedule, and it has a grand total of two games, one pre-game, and one southwest sports report for the entire months of January and February. Not TWC's fault, but still disappointing. The schedule can be found here: http://msn.foxsports.com/name/HD#FSSouthwest.
Yeah, I am hoping they add them soon too. I am considering buying OTA capability, but I don't have an ATSC tuner, so it isn't as simple as just buying a cheap indoor antenna. If I had any idea what the ETA was for FOX and ABC it would help me decide either way.
Still, after browsing the HDTV programming forum, I have to say that TWC here is a pretty good deal.
post #78 of 1588
It took me a moment to notice last night that TWC has added KFOX-DT to it's lineup as channel 1304! I managed to catch a bit of American Idol in HD and it looked great. Woo hoo!
post #79 of 1588
Is it just my antenna or is kfox dt ota down. This is very bad because the super bowl is in just a few days
post #80 of 1588
I am in LC and the same thing has happened to me. I haven't checked it today, but last night around 9pm the signal was gone.
-daniel
post #81 of 1588
i also live in las cruces and lets just hope they can fix it in the next few days because i really dont wanna watch the super bowl in sd. Also did anyone contact kfox via email they usually respond quickly
post #82 of 1588
I live in El Paso and I checked tonight - no signal. I did email them just to make sure they were aware it was down. I hope they get it back up in time for the Super Bowl. I don't have cable TV and I want to watch the game in HD too.
post #83 of 1588
Cable wouldn't help - cable gets is signal from the OTA broadcast, after all. I just checked and the signal is still out to lunch.
I'd be very surprised if they didn't get the signal back up for the Super Bowl, but wouldn't that be a rotten surprise?
post #84 of 1588
i wonder if this has anything to do with them adding their signal to time warner and comcast (possibly before super bowl) in las cruces this week. They could also be upgrading the tower as I have heard something about this possibly for more bandwidth or something like that
post #85 of 1588
AFAIK TWC adding the signal just means TWC picks up the OTA signal and rebroadcasts it over cable (same for Comcast). If that is indeed the case, it should mean that the Fox station doesn't have to do anything different at all.
They could definitely be upgrading hardware of some kind. If so, I hope it goes quickly...
post #86 of 1588
kfox is back on man that was a scare. Comcast is now broadcasting kfox dt on channel 113
post #87 of 1588
I'm not sure exactly how long KTSM has been out, I have been away for awhile. Anyone else not getting a signal? I am about to email KTSM and find out whats up.
---mkztg
post #88 of 1588
HDNET TO BROADCAST GAMES 2-5 OF FIRST ROUND IN PLAYOFFS
For Immediate Release- April 23, 2005
DALLAS - The Dallas Mavericks and HDNet announced today that fans will
be able to watch Games 2 through 5 of the Mavs vs. Rockets Round 1
Playoff Series in high-definition on HDNet in Texas.
"There's nothing more exciting than playoff time, especially when you
have a match-up featuring two Texas teams," said Mavs owner Mark Cuban.
"HDNet and the Mavs want to give viewers at home an experience that is
almost as good as being there."
Co-founded by Cuban and General Manager Philip Garvin, HDNet provides
viewers with exciting and topical news, sports, music and entertainment
programming. The network features up to 20 hours of original
programming each week, all produced in the highest quality 1080i HDTV
format - more original high-definition programming than any other
network.
HDNet news and entertainment includes original series "HDNet World
Report," "Face 2 Face with Roy Firestone," "Art Mann Presents," "HDNet
Concert Series," and "True Music," as well as every episode of the
acclaimed Warner Bros. series "Smallville." Live sports productions
include NASCAR auto racing, National Hockey League and Major League
Soccer games.
HDNet Movies, the company's second network, shows a wide selection of
major studios' theatrical releases - all uncut, unedited, and appearing
in their original aspect ratio. The network also features movies
produced and finished in true 1080i high-definition, including movies
premiering day and date with their theatrical releases.
Fans can contact their cable or satellite providers or visit www.hd.net
for more information. Comcast does not currently carry HDNet and HDNet
Movies, so Mavs Playoff games in HD are not available to Comcast
customers. Comcast customers are asked to call their local office and
let them know they want HDNet and the Mavs in HD.
MAVERICKS 2005 PLAYOFF HDNET SCHEDULE
(All Times Listed CT)
Game 2 Mon., April 25 - Rockets @ Mavs 8:30 p.m.
Game 3 Thurs., April 28 - Mavs @ Rockets 8:30
p.m.
Game 4 Sat., April 30 - Mavs @ Rockets 4:30 p.m.
Game 5 Mon., May 2 - Rockets @ Mavs, if necessary TBD
post #89 of 1588
Anybody else hear that KVIA has upgraded their HDTV antenna to a high powered antenna? Soon KVIA will be able to be seen easily by Las Cruces and other nearby areas. I also saw that hopefully the antenna will be fully up and running later this month..KVIA is the hardest channel for me to get right now in El Paso..it has tons of dropouts at my location, so this is good news for a lot of us that can't get KVIA very well right now.
post #90 of 1588
yes kvia is the weakest signal i live in las cruces and couldn't get any signal whatsoever do you know when they plan to go full power?
