AVS › AVS Forum › HDTV › Local HDTV Info and Reception › El Paso, TX - HDTV
El Paso, TX - HDTV - Page 4
post #91 of 1588
Horizon City
4-1 KDBC - Working.
7-1 KVIA - Not Working. Was before, but now it is out.
9-1 KTSM - Working.
13-1 - 13-2 KCOS - Working.
14-1 - 14-2 KFOX - Working.
22-1 KRWG - No Signal
26-1 No
38-1 Yes
48-1 No
65-1 No
Did ABC drop down? When will they be full power?
post #92 of 1588
i have never been able to receive kvia-dt but im guessing it is down so that they can upgrade to the full power antenna keep me posted when you can get the channel again.
post #93 of 1588
RBA,
Mind if I ask what kind of receiver you're using? I lost KVIA as well. A few years back I had a Hughes E86 and one day KVIA-DT just dropped off the map. KVIA even sent a couple techs out to my house and brought a Samsung HD receiver with them to prove that they were still up and running. Everyone was kinda stumped at that point. The guys from KVIA pointed the finger at Hughes and when I called Hughes, they said it was probably a problem with something in KVIA's stream
I never did find a resolution to the problem, and just ended up buying a new receiver (a Hughes HTL-HD) I just want to get an idea if they're down for everyone, or is this just a Hughes thing again?
If they are just down for the upgrade to full power, couldn't they have found a better time than the last week of the NBA Finals?
post #94 of 1588
i agree they should of upgraded a long time ago now they only have a few days till the july 1st deadline to be full power. Im looking forward to july 1st because they only channel you can receive in las cruces is fox and on the 1st I should be able to get all of them
post #95 of 1588
Originally Posted by JoBoo View Post
RBA,
I had the E86 and everything was working fine. I recently switched to the Directv HD Tivo (jump on the 50 percent coupon at Best Buy) and noticed KVIA was out. I don't know if it was out on the E86 just befor the switch, but the new HD Tivo is not working for KVIA.
post #96 of 1588
You have a lot of faith.
post #97 of 1588
yeah lol I know kdbc is going full power on the 1st. Dont know about the rest though.
post #98 of 1588
Hi there,
I just got a new Digital Stream HD 3150, from Circuit City..it was a cheapy brand..but wow the picture is amazing. Seems to work really well and I'm planning on keeping this puppy.
Well moving along to the signal meter:
4-1 KDBC - Signal = 86, SNR = 29.76 db (I think they went to full power a few days ago)
7-1 KVIA - Signal = 72, SNR = 21.55 db (They are back, but not at full power yet)
9-1 KTSM - Signal = 75, SNR = 23.80 db
13-1 - 13-2 KCOS - Signal = 76, SNR = 23.96 db
14-1 - 14-2 KFOX - Signal = 86, SNR = 29.75 db (They've been at full power for a while)
22-1 KRWG - Still can't get a good signal.
Channel 7 seems to be back with a better signal..I no longer get any dropouts..but they still don't seem to be at full power like they claimed they would be..so hopefully soon they will turn their antenna to full blast.
Also, I have to say that the picture quality looks amazing on every channel with hardly any dropouts here in the Eastside of El Paso.
post #99 of 1588
Well it looks like 7-1 KVIA is back down again..I guess they are working on the antenna today..it was working earlier when I made the post, but I guess they are doing more technical stuff on it.
Maybe they'll get it up to full power?
post #100 of 1588
lets hope so raid for us in las cruces!
post #101 of 1588
You might of gotten your wish 49ers, because Ch. 7 is back up and showing up with a stronger signal on my reciever.
7-1 KVIA - Signal = 83, SNR = 27.40 db
Hopefully you guys in Las Cruces can now get the signal.
post #102 of 1588
Getting Peak at 88 and low of 73 this morning on KvIA 7-1 No drop outs!
A peak of 90 and constant 89 on KTSM 9-1. No drop outs.
A constant 90 on KFOX-DT 14-1. No drop outs.
Constant 72 on KDBC 4-1 with Peak of 80. No drop outs
Constant 88 on KCOS-DT 13-1 No drop ots.
constant 71 on 39-0 KSCE
Location Horizon City with Directv HD Tivo.
post #103 of 1588
As of this post (10:49a 2 Jul) I'm getting no signal from 7-1.
post #104 of 1588
Same here RBA, I guess they are still working on the antenna..so the signal comes and goes.
It's 1:27pm and ch. 7-1 is still out.
post #105 of 1588
It's back..Ch. 7-1 is back on the air with a signal in the 80's for me.
My guess is that they will be working on the antenna for a few days or even weeks..so the signal might come and go, but lets hope they keep it up for good soon.
post #106 of 1588
well i can get cbs and fox now no problem just nbc and abc are still weak here in cruces. I drove past the franklins where all the antennas are. I saw some new antennas which im guessing are the digital ones but they were not as tall as some of the other ones.
post #107 of 1588
from Alamogordo (90 mi away) the readings are (7/2/05)
4-1 CBS Signal = 56 (varies wildly)
7-1 ABC Signal = 85
9-1 NBC Signal = 82
13-1, 13-2 PBS Signal = 76
14-1, 14-2 FOX Signal = 80
generally lower am, higher pm
cm4228, cm7777
post #108 of 1588
hmm maybe its because i have a indoor silver sensor that i am having trouble getting abc and nbc
post #109 of 1588
Yup, in your case an outdoor antenna is probably the best solution for you. If I were you, I would try the CM4228 first, it seems like it gets good results.
post #110 of 1588
its odd because someone else is using an indoor silver sensor too in las cruces only about 3 miles away from me and can get every channel.
post #111 of 1588
Can some1 confirm if you are getting a HD signal from KVIA, I have channel 7 but not 7.1 or 17.1. I'd just installed my outdoor antenna and this is the only channel I'm not able to see.
Thanks for any reply.
post #112 of 1588
they've been down awhile
post #113 of 1588
Just called to the station, they said the tube burned and they are expecting the replacement from London but that due to the explosions is delayed but they also said the HD signal will be up and running by Tuesday 19th.
I hope this is true.
post #114 of 1588
ktsm added another sub-channel (for weather)
post #115 of 1588
I wanted to know if TWC offers cable cards or if their HD boxes have firewire out? It usually is a small 4-pin connection called 1394 or DTV Link. My Toshiba has a slot for it and I want to use it to record HD. I am probably the only one in El Paso that ones a DVHS recorder. Does any one know if TWC activates the copy-protect flag?
post #116 of 1588
is kvia back up and i also lost kdbc is that out too now?
post #117 of 1588
KVIA still not up, KTSM is UP, .1and .2
post #118 of 1588
I'm still getting kdbc
post #119 of 1588
im getting kdbc again sorry about that
post #120 of 1588
KVIA is still down..have they even been working on KVIA's signal lately?
