| Originally posted by RichB ...I know the Aurora approach is to goto almost native rate. What is the KD approach?...asinshesq or other 503CMX users, Have you tried watch a news ticker channel like Fox or CNN with the HDL at native rate. This is a good way to check for video for motion problems. -- Rich |
In order for it to work on the digital Leeza, people had to go to a 72hz refresh rate - 60hz was resulting in some image instability. On the HDL, Mike T has said that things are different and that he finds 60hz to work best with the 503cmx...but I have recently found that at 60hz DVI is a bit shaky on the 503cmx (the image jiggles a bit, particularly in the lower half of the screen). I haven't heard from others using the HDL-503 combo as to whether they see the same problem at 60 hz.
