AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Savannah, GA - HDTV
Savannah, GA - HDTV - Page 74
post #2191 of 2578
A lot of these "Feeds" are not carried in HD. The Atlanta Falcons preseason game "Feeds" are never in HD but the FOX national coverage of a Preseason Game is always in HD.
post #2192 of 2578
Forgive me if this has been covered in a previous post. Does WJCL not broadcast their primetime shows in DD 5.1? All my Digital Tuner will pick up is 2 channel stereo.
post #2193 of 2578
As of now 11 and 28 DD5 ,3 and 22 are not, but it could be the program. Both 3 and 22 are not HD
post #2194 of 2578
WSAV with no HD tonight. That really sucks.
post #2195 of 2578
I called them over 30 minutes ago, still no HD. they just said it was a network issue.
post #2196 of 2578
I'm so glad I have an antenna, I'm watching it in HD from the Augusta Affiliate.
post #2197 of 2578
So much for the "network issue" excuse.
post #2198 of 2578
Since nobody has said anything in 10 days, I wonder if we'll get Oprah, Dr. Phil, Ellen, or Entertainment Tonight in HD, since they are all being offered in HD now. Or when will FOX28 will show us Raycom Sports SEC football in HD?
post #2199 of 2578
Or when we will get some CW in HD
post #2200 of 2578
My first time to watch WJCL HD OTA NASCAR in on ABC. The mouth is not with the words. How disappointing.
post #2201 of 2578
Is it just me.....or does anyone else notice WSAV HD live broadcasts of sports have ever so slight blurs, if you start noticing it can become annoying.
It's not my TV, Ive noticed on two different sets. I do have my antenna running thru my 622 Dish. I never notice this on any other networks nor do I notice it on anything but live HD sports broadcast on WSAV.
post #2202 of 2578
NBC has some of the worst HD going. It is not just you.
post #2203 of 2578
From what I've read, it's a combination of your display and the Broadcast. The Olympics, on both WSAV and WAGT out of Augusta produced really bad motion blur, most notably with Olympic Diving. Both stations have a sub channel. Watching the NBA finals on WJBF out of Augusta, with a sub channel, produced really bad motion blur when Transitioning from Graphics on the screen to the actual game play, however on WJCL this phenomena was not present. So there could be some Bit Starvation causing these issues.
post #2204 of 2578
Thanks rjknyy and groove93 for the response. Makes sense.
post #2205 of 2578
I emailed WGSA(The CW) about two weeks ago asking if they had an idea on when their shows will be in HD. This is the response I just received:
"Ch. 35 is digital and network shows are now upgraded, but will be true HD
within a few days. Tower is located at I95 and SR204"
post #2206 of 2578
The CW is now in HD! Somebody from a station was actually right about their time frame for HD!
post #2207 of 2578
DirecTV has updated the Local Channels web site and now shows October 8 as the date for Savannah local stations in HD on satellite. Here is the link.
http://directv.com/DTVAPP/global/con...ssetId=3620002
This will be good for those of us out on the fringes where signals are spotty during the day. Of course you need DirecTV's HD package to get them.
post #2208 of 2578
Not to be picky, but it says October 08, not October 8th. Either way, good news
post #2209 of 2578
It looks like DirecTV subscribers will be getting locals in HD tomorrow. This is according to an insider on dbstalk.com. Unfortunately, it may be minus FOX.
post #2210 of 2578
Nothing here. Not yet, anyways.
post #2211 of 2578
HD Locals are now working via Direct TV!!!!!
post #2212 of 2578
Still nothing here. Beautiful...
post #2213 of 2578
Did your reboot your system to update the Guide Data?
post #2214 of 2578
Yep, and signals on 99s are good too. I'm stumped.
post #2215 of 2578
I'm assuming your have Duplicates blocked in your guide list as well.
post #2216 of 2578
Are they supposed to show up when I'm hiding duplicates? I didn't see them. When I left, they were only showing up in the All Channels list, but no other, and only when showing duplicates. Favorites doesn't have the option to add them. Maybe they need to populate to other channel lists.
I'll see how it looks when I get home. Thanks anyway.
post #2217 of 2578
I didn't have to make any changes or adjustments, they just showed up this morning. My DVR has always been set to "Hide SD Duplicates".
post #2218 of 2578
Do you use a Favorites list?
post #2219 of 2578
They are there, but if you use a Favorites list you have to manually add them. Here is my story with an HR20-100 with "Custom 1" as the Favorites list.
Formerly had all the SD feeds checked (3, 11, 22, etc.). I also have OTA capability and so had the 3-1, 11-1, 22-1, etc., channels in the list and in the guide. Today all my normal old SD locals were automatically removed from the Favorites list. I went in and edited the list to add them back. The ones that were removed were the HD feeds added today: 3, 11 and 22. My 28 and 34 and 9 favorites were still there.
Right now looks like we have ABC, CBS and NBC only with HD feeds. I have "Hide SD Duplicates" enabled, and my new HD local feeds are the plain channel numbers where the SD local formerly were. In other words, 3, 11 and 22 with no dashes or anything.
post #2220 of 2578
No Favorites list and after reading Bmeeks response, I am using an HR21-100 which has no OTA capability. So if you have an HR20, you may need to make the those same adjustments. I have an Antenna and I'll keep it for the Augusta Affiliates, unless someone has a workaround besides the AM21.
