AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Will component to vga cable work for Davis 650?
post #1 of 2
Will this cable work from the xbox to the davis 650?
http://www.pccables.com/cgi-bin/ord...48&partno=02803
Andhow exactly do you connect this to the xbox? The hi def pack only has 3 component outputs and the cable shows 5? how does it physically get connected? thanks!
post #2 of 2
No, you will need a transcoder
This thread is locked
