Mine has a dust problem and it is ceiling mounted. The theater is clean and I have an air filter (one step down from a hepafilter) in the air return and an electostatic air cleaner.
Blew air on the back of the lens again to try to solve the dust spots. They are less noticable now, but some are still there. Some could live with it, but I won't after spending so much on a projector. I'm going to try a lens cloth next and see if that does the job. Also got the bulb numbers for Don and whoever else wants it. This is everything written on the top of the bulb.
TOP
OSRAM
VIP R 200/P22
GERMANY qn1
If anyone finds a good price on replacement bulbs, please share. I noticed the bulb has a spot or two of silicone holding it in along with the screws. Course, so does some of the mirrors.
And about DWIN claiming the light path is shielded from dust. Is this like their claim of a light sealed cabinet? And then they admit light spills out the rear fans. But it's still a light sealed cabinet. If you look at a certain angle with the cover off, you can see the DLP chip. It would be simple for dust to get all over the light path and on the DLP chip (unless they have a glass cover on the DLP chip, I couldn't see one). You can stick your finger between the DLP chip and the lens. That's not dust shielded. Maybe they were talking about dust falling on the outside cover.
TOP
OSRAM
VIP R 200/P22
GERMANY qn1
