Given that Replay has the ability to add new IR blaster codes to our boxes as part of their nightly download if they wish to do so, is there anyway that we could create and add our own IR blaster codes?
I'm encouraged by reden's recent accomplishments where he was able to let one of Mikeyboy's 2.0 Showstoppers get the 3.0 software using his linux box.
I have seen the IR blaster code files before and they are in a standard UEI format, so I could certainly create the data that needs to be loaded if someone else knows how to get it into the units.
Then we could start adding codes for HDTV receivers and off-brand cable boxes! I have an HDTV receiver that I acquired as part of an Ebay deal and I'd love to be able to hook it up to Replay, if only to get crystal clear reception on the local OTA channels.
PLEASE NOTE: Even though I started this topic, I have been too busy with other things to keep up with the progress that has been made in adding new blaster codes to Replays, so I'm not the person to ask how to do it.
Update 6/16/2007: This thread is now just for the 4k/5k series units (that use RID files). I have split off the posts concerning the 2k/3k/Showstopper units (that use OBJ files) here:
http://www.avsforum.com/avs-vb/showthread.php?t=862213
All files related to adding blaster codes to Replay can be found here...
http://www.hifi-remote.com/forums/dl...ory&cat_id=106
FlipFlop's "step by step" is here:
http://www.avsforum.com/avs-vb/showt...29&post6677629
http://www.avsforum.com/avs-vb/showt...95#post6311995
