AVS › AVS Forum › Gaming & Content Streaming › XM and Sirius Satellite Radio › Extending antenna cable?
post #1 of 8
Anyone found a way to make a longer cable for the XM home antenna, whats inside? is it just really thin copper conductor with no shield? Anyone?
post #2 of 8
Its a pair of coax cables, a copper solid core and a braided shield.
post #3 of 8
I was referring to the antenna/satt not the audio cables. It is long thin and black.
post #4 of 8
Yep, thats what I was talking about. It is a small pair of coax cables, one for the rf antenna signal and one for the sat signal. In the new models it'll only have one cable.
http://store.yahoo.com/xmfanstore/anspxm25foca.html
http://store.yahoo.com/xmfanstore/anspxm25foca1.html
http://store.yahoo.com/xmfanstore/tetranexca.html
These should help you. :)
post #5 of 8
My connector does not look like that. It has "1" plug...like a tiny RF connection. It is a delphi unit...that is probably why we are crossing signals here. Thanks for the input so far.
post #6 of 8
Ok, this one then? http://shop.store.yahoo.com/xmfanstore/anexcasa.html http://store3.yimg.com/I/xmfanstore_1739_742105 But it looks like it is discontinued, another one is coming out.
You can use this one though, http://shop.store.yahoo.com/xmfansto...pxm25foca.html
It says "To use with the Delphi home kit, you will have to "pop-off" the colored plastic housing (instructions included)."
http://www.xmfan.com will be able to help you more.
post #7 of 8
JamesMH thank you for all your help. Looks like there is a new receiver base that has a diff style plug?
Thanks again. My new homeowners will be happy to hear they can get XM on their new whole house audio system.
Jon
post #8 of 8
No problem. Yep a few different plug styles out there. Let us know how your house install goes.
  Back to Forum: XM and Sirius Satellite Radio
This thread is locked
