Originally Posted by
MSpin
Where do you see that they are moving back to 10? Their construction permit for DT shows them at 52. I know that 52 - 69 are only temporary channels but I don't see anything saying they will be at 10. At least I hope not, VHF would tick me off since I would need a new antenna.
Their "first round" in-core channel selection to use post-transition is VHF 10, and they chose no alternate channel. The application is
HERE.
They can't use ch 52 post transition anyway, because the only TV channels left will be 2 thru 51. 52 thru 69 will be auctioned off for new "wireless" services. So it's highly likely they'll get to move back to 10 when analog goes dark.
I wouldn't worry about the antenna until then though. Most highband VHF chs (7 thru 13) can be received with an antenna designed for UHF-only. And if not, a good
V/U preamp will usually be all you'll need to add.
