Originally Posted by arxaw
If she can take the TV back, do so and trade it for a Sony, Sanyo or LG. They are very good for weak signals like KOZK and kolr. Just curious, what brand converter box did she have?
arxaw,
I believe her first converter was the Zenith, she also had a RCA. Both worked well in that room with the same antenna. I'll let her know about changing tv's.... although she got a very good deal on the Sammy
One possibility is that something near the antenna or the TV itself may be interfering with reception, (particularly stoopid low power VHF). Try moving the antenna as far from the TV as possible. To extend the coax length, use a barrel splice, if the coax is hard wired to the antenna.
She did get in touch with a KOLR engineer. They are sending her a FM trap. I don't have high hopes, but you never know. We'll also try moving the antenna away from the tv. The coax is not hard-wired.
Also, amplified indoor antennas don't usually help VHF reception and can make it more prone to interference. Try a passive indoor antenna like the RS budget model.
arxaw,
The engineer at KOLR also told her this. We're gonna try about every configuration possible to get that station. She doesn't really care for PBS, so no huge deal there. But 10 is a different story.
Sincerely appreciate the help and will report back Friday/Saturday with current status.
Big thanks for the time & help.
Jeff
