AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Springfield / Joplin, MO - HDTV
Springfield / Joplin, MO - HDTV - Page 174
post #5191 of 5400
Originally Posted by justpushplay View Post
Just checked, and no, my guide stops at 33.1. It does show the subchannels for KY3 and KOZK, however.
I just wondered because my DTVPal DVR shows all the OTA channels,
but since the CW moved from 3.2 to 33.2 all I get for it is PSIP info, not TVGOS.
post #5192 of 5400
Same here, but my Dish OTA tuners channel lineup still show ky3's no longer active 3.3 subchannel, which was AccuWeather, or something like that.
post #5193 of 5400
My Dish OTA tuners quit showing the non-existent KYTV 3-3 channel after I rescanned the boxes for OTA channels. These are model 722K boxes with OTA modules, so YMMV.
post #5194 of 5400
Yup, my mileage varied. I have the 622 and the 211, and both refuse to drop 3.3 in the guide. If you go to 3.3, you get that horrid Windows 3.1 style dialog box #739 stating that you have lost signal.
post #5195 of 5400
It was "KY3 24/7" weather, which was moved to 3.2.
post #5196 of 5400
i tend to thing that channel 8 is closed up shop for good, i think a simple retooling would not take more than a month,,, so it looks like no more Happy Days
post #5197 of 5400
They could be putting something else on 3.3
What's on Channel 8 besides Happy Days?
post #5198 of 5400
Can anyone recommend a signal booster for OTA TV? Here is the situation:
I live in Ozark and get all OTA signals fine, except Fox. I actually can get Fox but I have to split the signal four ways and that kills it (although other channels are not impacted by the split). I run one cable to the TV, two to a network tuner and one to a Win 7 computer used exclusively as a DVR. I thought a booster might work in this situation although I am unsure how much of a boost I really need. I'm a bit baffled by all the options and wonder if anyone can recommend a specific brand/model.
post #5199 of 5400
post #5200 of 5400
Thanks for the recommendation. I'll give that one a shot.
post #5201 of 5400
I haven't heard any recent reports on KRBK's various transmitter sites.
Have they completed the synchronization process and come up to full power?
Are there any reports from viewers roughly equidistant from two transmitter sites?
I'm line of sight to the Division St antenna so, of course, they come in like gangbusters.
post #5202 of 5400
They have not posted any updates on Facebook for quite a while now.
Edit:
They did post a short update on Wednesday 22 Feb here.
post #5203 of 5400
Anyone in SW MO picking up KXNW?
post #5204 of 5400
Nothing so far here near Branson West. I noticed you had asked if anyone else had lost their signal the other day on the Fort Smith thread. Are they installing the new transmitter?
post #5205 of 5400
I don't know. I never could get an engineer to reply to my email. I called KFSM, who runs KXNW, and all they would tell me is that they were off the air for a while and were working on it. No info on power upgrade, but if you're not seeing them, I suspect it's not completed and may have been pushed back.
They are back on the air, though.
34-1 IDs as "KXNW-MY" (in SD) and 34-2 as "KFSMCBS" (in HD).
post #5206 of 5400
They must still be at low power, I just scanned again with no results. If they were running the same ERP as they used to, I would have no trouble seeing them.
post #5207 of 5400
They haven't run at that power level in a long time.
post #5208 of 5400
I don't think this on-channel multicast, or whatever it's called has ever been done in practice and at full power levels.
It could be a while before they get it all to work. Or maybe it will never work all that well.
Edit:
post #5209 of 5400
Its called an SFN (Single Frequency Network) and supposedly this one is only the third in the US.
post #5210 of 5400
Or maybe a distributed transmission system (multiple transmitters) in FCC parlance.
http://en.wikipedia.org/wiki/Distrib...mission_system
In any case it's pushing the limits of technology. That's a wonderful thing unless you just want to watch TV and can't do it.
post #5211 of 5400
...That's a wonderful thing unless you just want to watch TV and can't do it.
Reminds me of trying to watch kolr10 during severe thunderstorm season.
post #5212 of 5400
Or KOLR in general. That VHF signal is TRASH.
post #5213 of 5400
I recorded a couple of shows on the 20th (KRBK) and they were so broken up and pixelated I just deleted them as unwatchable. I am unsure what the weather was on that day... Shows recorded on the 21st are fine.
post #5214 of 5400
That depends on where you live. In my location (about 20 miles south of the tower farm) the signal is great.
Edit:
If you're using a UHF only antenna I imagine the signal might be trash...
post #5215 of 5400
Their weak VHF signal is the problem.
KAFT to the south of us on VHF ch 9 at 40kW works fine, except during the worst of lightning events in the region. Since kolr can't raise power, they should get off the VHF band. Hell, swap with kozl, nothing's on that channel anyway.
post #5216 of 5400
..except crap. Makes me long for Equity and My31. Oh wait, KRBK is even more entertaining (if you can get them)
post #5217 of 5400
I'm about 13 miles west of the towers and get an excellent signal with all of them (even KOLR10) except KRBK. I'm trying to watch American Idol, and I typically make it about 30 minutes into an episode before just turning it off, because sometimes the signal pauses for 5 seconds every minute or so. If it's going to be that bad, then I'm just going to watch online or download a non-pixelated version of the show.
post #5218 of 5400
They still have a long way to go before KRBK is at full capacity.
See their latest status update.
post #5219 of 5400
Well, that's encouraging. I can endure short-term hardship if they're working towards a good signal in the long term.
post #5220 of 5400
I've gotta admire KRBK for advancing the state of the broadcast art. Bob Koplar has never been afraid to experiment.
Several decades ago when interactive TV appeared to be the coming thing he was at the forefront.
If they get this to work, maybe they will add yet another site to the south.
Would that be too far from their city of license?
