AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Springfield / Joplin, MO - HDTV
Springfield / Joplin, MO - HDTV - Page 181
post #5401 of 5450
Anyone getting KRBK on DirecTV? My wife watches "so you think you can dance" and every few minutes the picture goes black for 2-3 seconds, then comes back and the audio cuts out and is out of sync for a second or two. This only happens on KRBK and no other channels, so I don't think it is my equipment. OK fine, I watch it too... smile.gif
post #5402 of 5450
Why not E-Mail the KRBK engineer?
His name is Bret Falcetto and his address is:
bret@krbktv.com
post #5403 of 5450
Is there anyone who had someone do their antenna install, recommend an installer?
post #5404 of 5450
I haven't used him, but Bill Chambers in Ozark did a lot of antenna installs
when KRBK first went to their new transmitting system.
PM me for his phone number.
post #5405 of 5450
I find it interesting when I contacted KRBK asking how to best pick up their station OTA and told them my location the station said for best results an attic/outdoor antenna would need to be pointed toward Branson.
post #5406 of 5450
I don't know your location, but besides the transmitters that make up KRBK's new SFN they also have a deal with KWBM channel 31.1 to share their frequency. Those receiving KRBK
via KWBM see channel 49.1 displayed, but its actually RF ch 31.2.
KWBM's transmitter is located in Taneyville, so folks living south and southeast of Springfield get a pretty good signal.
post #5407 of 5450
He gave his coordinates earlier. Here's the TVF plot for them: http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d0559c515595e06
Based on that alone, it's a tossup for KRBK's Springfield transmitter and KWBM. However, those coordinates appear to be on a wooded, south-facing hillside 1bout a 1/4 mile north of US 62, just east of US 65.
Looks like a crapshoot. Until he actually puts something, anything, up in the air, there's no way to know what will actually work. Probably KWBM for Fox given the terrain.
post #5408 of 5450
Is Channel 39-1 gone?
We used to get it, although somewhat intermittently, but haven't gotten even a whiff of it for 2-3 weeks.
post #5409 of 5450
Well can't pick up KRBK with a single Clearstream V2. Looks like I am resigned towards a two antenna attempt with the second aimed toward the KWBM tower. Other suggestions are welcome. Those of you who are getting KRBK along with other broadcast networks what are your setups? I'd especially like to hear successful setups in Ozark.
post #5410 of 5450
Where have you placed the Clearstream 2v for testing? What aiming directions have you tried? Can you pick up KWBM when the antenna is facing its direction.
post #5411 of 5450
It was placed on the roof mounted on an old Dish Network mount. We aimed toward Springfield and between Fordland and Springfield with an Antennas Direct CPA 19 preamp and couldn't even get a whiff of a signal from a Springfield KRBK tower. Haven't tried aiming toward the KRBK tower yet. My installer is supposed to be getting an additional antenna and equipment and trying again before the end of the week.
post #5412 of 5450
I'm not sure why you would need a preamp in Ozark. I get all the channels except FOX with an old $20 Radio Shack special in the attic. I live just south of the city line (like 100 yards).
FOX is another story. Coverage with their toy antenna system is so spotty I could live right next door to you and own identical equipment... one of us might get reception and the other not. Yes, the coverage really has that many holes. I got KRBK when they first fired it up but lost reception when they started "tweaking" the system for "improvements". Now I couldn't buy a signal from the KRBK tower in Springfield. After a few months they evidently made an arrangement with KWBM and I started picking up that signal. Exactly how I'm getting KWBM is a mystery. The antenna isn't pointed in that direction. I had blown off FOX as a lost cause and didn't do anything special. Still just the old $20 antenna pointed at Fordland.
post #5413 of 5450
I live about 10 miles southwest of Ava, so I get good reception of all the stations
being broadcast from Fordland as well as KRBK's KWBM signal.
My antenna is pointed at Fordland and gets the KRBK\KWBM signal just fine.
BTW I too use a 20 or 25 year old Radio Shack outdoor antenna.
post #5414 of 5450
I was trying the preamp off a recommendation on the tv fool forum. That sure is interesting that you are getting KRBK but aren't pointed toward the KWBM tower while located on the side of town with Walgreens, Walmart, Lowe's, etc. I'm located sort of uphill from the park area. Wish I could get it with a single antenna.
Edited by mulliganman - 7/25/13 at 1:02pm
post #5415 of 5450
I was trying the preamp off a recommendation on the tv fool forum. That sure is interesting that you are getting KRBK but aren't pointed toward the KWBM tower. I'm located sort of uphill from the park area. Wish I could get it with a single antenna.
Just checking - you do know that KRBK's signal through KWBM shows up as 49.1
but is actually broadcast on RF ch 31.2.
If I was in Ozark, I'd try aiming my antenna just south of Fordland in hopes of getting those stations plus KRBK\KWBM...
post #5416 of 5450
Yes. We were looking for 49.1 but weren't having any luck. We did pick up the other channels just fine. I can have him try aiming again just south of Fordland. I am just hoping I pick it up somehow. Antenna Web says I can pick up KWBM if an antenna is installed 30 foot above ground.
post #5417 of 5450
Well I guess I should say Antenna Web is saying I can pick up KWBM channel 31.1 . I assume it is the same.
post #5418 of 5450
Yes.
post #5419 of 5450
Thought I'd update. The install was finished today. I could get KRBK pointing towards the KWBM tower in the Branson area with a directional antenna but signal strength was only in the mid to low forties. So we aimed toward Bolivar and are picking up KRBK with a signal strength in the seventies.
post #5420 of 5450
I'm considering getting an Antennas Direct DB8 to receive Springfield, Joplin, and KC channels in El Dorado Springs.
I currently have an indoor Winegard SS-3000 and am able to getting KRBK and sometimes other Springfield channels throughout the day. Often at night and in the mornings, I can get all of the Springfield channels, some Joplin, and some KC. I have really been surprised how much I get this far out, and believe that a good outdoor antenna would really work well.
Any thoughts?
Edited by nroden - 8/20/13 at 10:55am
post #5421 of 5450
If you post a link to your exact location TVFool plot, we'll be able to make a specific recommendation.
The Db8 is an antenna focused on UHF reception and, for weak signals, must be well-aimed. You might find it to be a basic building block of a complete system that includes a rotor, pre-amplifier (perhaps), and a high-VHF antenna.
post #5422 of 5450
post #5423 of 5450
I'm approximately 60 miles NW of Fordland and aim my antenna at 118 degrees. I have a cheap zenith digital tuner I use on an old tv in my basement (not HD) - it scans in 49.1 just fine.
My high $ samsung HD tuner running off the same antenna won't scan it in. All other channels (3, 10, 21, 27, 33) are crystal clear on the samsung. Any ideas why the samsung can't find it?
post #5424 of 5450
I sure would like to watch the World Series!!!
If anyone from KRBK is reading this thread: YOUR STATION SUCKS!!
Who's stupid idea was it to arrange your transmitters that way???
Why can't you just broadcast from Fordland like all the other major networks in SGF???
post #5425 of 5450
Can you add a separate antenna for the FOX station? Or adjust the aim of you current antenna? Is that channel UHF, VHF, or just too far away? I understand this can be aggravating. Fortuntely at my location, I can now receive 2 strong FOX signals, as well as 2 CBS and 2 NBC. And 1 ABC regularly, and 2 usually at night. And several PBS. Have you explored all options? Good luck.
post #5426 of 5450
post #5427 of 5450
sounds like MeTV is coming to KRBK in January. It shows on the Metv site and also elsewhere wink.gif
post #5428 of 5450
Good to know. lake TV is know.on Co-Mo Connect and has it in HD but no KY3 Westher Plus yet and it and Charter,Sudderlink don't have KRFT Digital Sub Channels or otters that Springfield gets.
post #5429 of 5450
Well, came home today eager to watch the Chiefs game. And there was no signal for KOLR. I am thinking ice buildup from the recent storm. Other channels are all coming in fine, though. Does ice affect VHF elements worse than UHF?
post #5430 of 5450
You didn't say your location. I'm about 10 miles southwest of Ava, and KOLR is coming in fine.
