AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Springfield / Joplin, MO - HDTV
Springfield / Joplin, MO - HDTV - Page 182
post #5431 of 5449
Bolivar.
post #5432 of 5449
Its been pretty windy. If you use an outdoor antenna you might check to see it hasn't moved...
post #5433 of 5449
Well I have been officially "blocked" from KRBK's facebook page after pressing them as to why their signal is consistently the lowest by far and why it is that all other channels still come in for me when we get winter weather but theirs doesn't. LOL!
post #5434 of 5449
You don't give your location. Are you getting your signal from the SFN in and around Springfield,
or from the KWBM signal south of Springfield?
post #5435 of 5449
The installer I had do my work for me said he was aiming toward Bolivar.
post #5436 of 5449
located in Ozark. My signal strength is now around 37% or so. Absolutely no issues picking up any other channels despite the snow.
post #5437 of 5449
It's absolutely ridiculous I can't pick this up ALL the time with a separate antenna + preamp+ distribution amp.
post #5438 of 5449
It's not their fault that you are on the back side of a hill facing away from their broadcast tower.
Edit. You realize that Bolivar is about 180° from where an antenna for KWBM needs to be aimed...
Edited by ProjectSHO89 - 1/5/14 at 1:55pm
post #5439 of 5449
Chuck,
What signal strength are you getting for KRBK off KWBM's transmitter in Branson?
post #5440 of 5449
Originally Posted by mulliganman View Post
Chuck,
I'm about 10 miles southwest of Ava, and with my outside antenna pointed north
towards Fordland, KRBK \ KWBM comes in at 75 to 80 on my Pal DVR's signal meter.
I'm close enough to the KWBM tower that it comes in strong even though my antenna
is actually pointed away from it.
post #5441 of 5449
OK so I realized the coordinates I had given earlier were wrong. Google maps was mixing it up with another street name with the same name in Ozark. A much closer representation at my situation would be: 37.0316027 -93.19952269999999
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d5b940f11af42d0
With that being said, do you all think I can pick up KRBK vis KWBM stronger than how I am currently aimed?
Edited by mulliganman - 1/6/14 at 10:24am
post #5442 of 5449
If you're in Ozark, everything except the new KRBK SFN is east of you.
post #5443 of 5449
Is anyone getting KRBK 49.2 ME TV? I have rescanned and cannot get it. I am getting 49.1 just fine.
post #5444 of 5449
Yes, been receiving METV for a couple of weeks on all TV's. No rescans.
post #5445 of 5449
So far its only being broadcast through the Springfield KRBK SFN on 49.2.
It remains to be seen whether it will also be available through the KWBM signal for those of us south of Springfield.
post #5446 of 5449
krbk towers are in bolivar and none can pick it up im 10 miles away and only picked it up when snow was on as soon as it melted it went off
post #5447 of 5449
KRBK has a total of 5 towers of their own (plus a piggyback sub-channel on a station down near Branson), one of which is in Bolivar.
You have to know where the "best" signal is likely to come from for any given location then aim your UHF antenna appropriately while avoiding the other signals.
Map of KRBK transmitters: http://www.rabbitears.info/contour.php?appid=1495755
Edited by ProjectSHO89 - 1/14/14 at 7:44am
post #5448 of 5449
New place!
I'm thinking about putting up an antenna and working toward re-cutting the cord at some point. Here's my Tvfool
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d5b94c2c7bb574b
Looks like I have a better shot at Springfield than I do Columbia stations. Some are 2edge so that's where I am concerned. Thanks for your advice!
post #5449 of 5449
Well, the good news is that KRBK won't be an issue...
A long as you aren't behind trees, you should be able to get it to work. Many Lake locations are pretty much SOL when it comes to antenna usage. Something like a 7698 and LNA200 should do the job.
